Key2Act Active User Define Fields
  • Key2Act Active User Define Fields
    Posted by MARY MALLAZZO on August 6, 2020 at 11:20 am
    • Mary Mallazzo
      August 6, 2020 at 11:20 AM
      Hello
      We are using Key2Act as a plug in for job cost.
      Does anyone know how to map the “Active User Define” fields?
      They are defined as read only , so we are presuming that they need to be mapped.
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Samantha Higdon
      August 6, 2020 at 4:25 PM
      Hi ,
      Assuming you mean the active user defined fields associated with Job Cost based on your question (as opposed to say service call management).Ā  If that’s a misunderstanding, let me know.
      Below is an excerpt from the Key2Act manual with instructions regarding Job Cost User Defined fields including the Active User Defined fields.
      1. ChooseĀ Microsoft Dynamics GP > Tools > Setup > Job Cost > User-Defined Label Setup > Job User-Defined.
      2. Label the third and fourth fields in the upper portion. The fields have attached lookup windows that open the Microsoft Dynamics GP Employee lookup list. You could label these fields to display an additional project manager, engineer, or other employee title.
      3. Label the remaining fields. The format of the fields is as follows:
        • 16 text fields
        • Two currency fields
        • Two date fields
        • Two check box fields
        • Ten active user-defined fields. Active user-defined fields are customizable user-defined fields. They can be defined to return various forms of data in read-only format. Unlike other user-defined fields, users don’t enter data in active user-defined fields. You can choose which active user-defined fields are visible by marking theĀ VisibleĀ check box next to each field. Contact Key2Act Sales for assistance with programming the active user-defined fields.
      4. ChooseĀ Save.
      I’m also including a link to the online manual that I referenced above.Ā  There’s more information about user defined fields related to Job Cost on this link as well as links within the page to other areas of Key2Act in case you need those.
      https://docs.key2act.io/signature2018r4/job-cost-user-guide/job-cost-setup/labeling-job-cost-user-defined-fields
      Samantha?
      Samantha Higdon ,CPA,CGMA
      Consultant
      Lagom, LLC
      Carmel IN
    • Mary Mallazzo
      August 6, 2020 at 4:47 PM
      Hi @Samantha Higdon
      It is the Active User define fields we were questioning.
      I will reach out to Key2Act to see how we assign fields to those fields.
      Thank you.
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
      August 20, 2020 at 8:21 AM
      Which integration program are you trying to use to ‘map’ the Active User Defined’ fields?Ā  Ā ?
    MARY MALLAZZO replied 6 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Key2Act Active User Define Fields’ is closed to new replies.
