Is it possible in GP to have two identical Invoice IDs but with a different vendor?
  • Is it possible in GP to have two identical Invoice IDs but with a different vendor?
    Posted by DSC Communities on December 21, 2016 at 4:45 pm
    • Rod Carlson
      December 21, 2016 at 4:45 PM
      If so, are there any special rules when importing into GP, for example from an eConnect Web Service or Smart Connect?
      Rod Carlson
      Information Technology – Software Developer
      YMCA of Metro Chicago
      Chicago IL
    • Brian Buhler
      December 21, 2016 at 5:06 PM
      As I understand it as long as the Vendor Numbers are different you can use the same invoice number in AP.
      Brian Buhler
      Kelsey National Corporation
      Los Angeles CA
    • Bill Marshall
      December 22, 2016 at 9:46 AM
      You can have duplicate invoices number whether they’re for the same vendor or not.  Check your Payables Management Setup window option: Allow Duplicate Invoices Per Vendor.  Options are Yes, No, or Recurring Transactions Only.
      Bill Marshall
      President
      mc²
    • Blair Christensen
      December 22, 2016 at 9:44 AM
      Yes.  The system has a key based on the combination of Customer/Vendor and order #.  Where you run into trouble is if the Customer/Vendor decides to wrap and start re-using order #’s. We had that happen a couple of months ago and we had to check with the customer about why they re-used a number because we couldn’t pull it in.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Thomas Hill
      December 22, 2016 at 1:07 PM
      I have one vendor whose invoice number is 20-xxxxx-99 where the xxxxx is a sequential number that restarts.  The 99 is a two digit number that is limited to their distribution centers with most invoices coming out of 11, 12, or 21 distribution centers.
      I have had invoices numbers dupe in a 12 month period.  For EDI purposes we strip the dashes and add the Julian Date, so our imports do not fail.  This is a big company with high volumes of sales.
      Thomas Hill
      Accounts Payable – Expense Processing
      M&A Technology, Inc.
      Carrollton TX
    • Thomas Hill
      December 22, 2016 at 1:08 PM
      I wish programmers would use a key of the vendor id + invoice number + invoice date.  That would be a really helpful key.
      Thomas Hill
      Carrollton TX
    • Rod Carlson
      December 27, 2016 at 9:04 AM
      Thanks very much to everyone. I will look into all of your points.
      Rod Carlson
      Chicago IL
The discussion ‘Is it possible in GP to have two identical Invoice IDs but with a different vendor?’ is closed to new replies.
