Inventory – Dex.ini swtich for Cost Adjustments AND Purchase Receipts Update Detail Report
  • Inventory – Dex.ini swtich for Cost Adjustments AND Purchase Receipts Update Detail Report
    Posted by Kyle Malone on October 28, 2019 at 4:13 pm
    • Kyle Malone, CPA
      October 28, 2019 at 4:13 PM
      We’re have issues w/ Cost Adjustments and while going through some Microsoft provided materials regarding cost adjustments, are prompted to make 2 changes.
      Microsoft Suggestion to see more detail regarding cost adjustments: Add REVALJEINDETAIL = True to the Dex.ini file
      Microsoft Suggestion to see more detail in out of the box reports (particularly the Purchase Receipts Update Detail (PRUD) report) – Add some special “PRUD Report package file” to GP.
      Has anyone implemented either/both?
      Ever run into any issues?
      The articles being referenced are from the 9.0 / 10.0 days and we’re on 2018 so I’m curious as to if anyone has made these changes recently…Ā  Maybe it’s unwarranted but I become a little concerned when there are ~7 year old enhancements that aren’t included in the core code of new releases.
      Original MS KB here –Ā https://support.microsoft.com/en-us/help/2448193/an-unexpected-gltrx-batch-appears-in-financial-batch-entry-in-microsof
      Kyle
      Kyle Malone, CPA
      Lead Consultant/Blogger – https://alacarteGP.com
      Solugence | Find the software that FITS your business + integrates with GP. Find Software Smarter. https://solugence.com
    • Matthew Arp
      October 29, 2019 at 10:09 AM
      I wouldn’t call them enhancements, more system options. For whatever reason they created them as dex.ini switches instead of making it a setting in some SYSTEM table. We use both of these options and haven’t noticed anything negative. But with that you should always test in a dedicated and independent test environment, but you already know that I’m sure šŸ˜‰
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • David Musgrave
      October 30, 2019 at 1:16 AM
      GPUG All*Star
      Don’t forget to use GP Power Tools Dex.ini Configuration to roll out the Dex.ini setting changes to all workstations/terminal servers.
      Sometimes when changes are made to code, Dex.ini settings are added by developers to allow the old methods to work as a backup/precaution.Ā  They are not necessarily designed to be an option that can be changed back and forth and so are never added to a setup window.
      Regards
      David?
      Managing Director
      Perth, Western Australia
      http://www.winthropdc.com
    • Kyle Malone, CPA
      October 31, 2019 at 1:38 PM
      Thank you & !
      I was hoping that someone else was using these options successfully.Ā  We put in Dev & all worked well so moved to Prod.
      Thanks for Dex info as well, all makes sense!??
      Kyle Malone, CPA
    Kyle Malone replied 6 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Inventory – Dex.ini swtich for Cost Adjustments AND Purchase Receipts Update Detail Report’ is closed to new replies.
