Increase size of AP check number
  • Increase size of AP check number
    Posted by MARY MALLAZZO on August 21, 2019 at 2:55 pm
    • Mary Mallazzo
      August 21, 2019 at 2:55 PM
      Hello
      Apparently our AP check number was setup with a length of 4.Ā  It just rolled over to 0.Ā  When we went in to change it to a 6 digit number, we received the msg:
      changing the length of the field may cause problems with auto-reconcileĀ
      Can we ignore this msg?
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Rob Klaproth
      August 23, 2019 at 6:42 PM
      Hi Mary,
      You can change your check to 6 digits, just add two 0’s to the last check number, i.e. if your last #Ā was 9999 and your next number is 10000 just make it 010000 for the next number.Ā  That will give you room to go up to 999999.Ā  If you think you’ll need more, I’d recommend another 0.
      The auto reconcile is the “reconcile to GL” function where you select a checkbook and it shows you discrepancies between the GL cash account and the checkbook balance.Ā  I’m not sure what “problems” may occur, but in my opinion, the reconcile to GL is not the bible in GP anyway, and a lot of people don’t use it.
      Rob Klaproth
      (GP Install & Configure)
      Sr. GP Consultant
      Nominated for GPUG All-Star 2019, Vote here 8/30: https://www.surveymonkey.com/r/GPUGAllStar2019Voting
    MARY MALLAZZO replied 7 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Increase size of AP check number’ is closed to new replies.
