Inactivate Vendors
  • Inactivate Vendors
    Posted by Tammy Harper on February 6, 2019 at 10:22 am
    • Tammy Harper
      February 6, 2019 at 10:22 AM
      Hi. I’m hoping someone can help me. We are trying to clean up our Vendor listing by making Vendors we haven’t used for a while inactive. The problem we are running into is we are receiving an error message that says, “This Vendor has been assigned a Purchase Order or an unapplied receipt. The status can’t be changed to inactive.” We are noticing this is happening on Vendors that have been in the system a long time. We have checked and there are not any open PO’s for these Vendors, or unapplied receipts. Has anyone else run across this problem and if so, were you able to get the Vendor marked inactive?Ā
      Thanks for any help anyone can give.
      Tammy Harper
      Charlotte County Airport
      PUNTA GORDA FL
    • Steve Burney
      February 6, 2019 at 11:29 AM
      Hello Tammy.
      It appears that you have made the correct steps to verify that there are no open documents for these vendors.
      One thing that I would recommend, if it has not already been performed recently, is to have your system administration person run the Check Links function.
      They can go to Maintenance – Check Links – Purchasing and perform this. They would know to perform this preferably when there is no one logged in.
      I hope this helps.
      Steve
      Steve Burney
      Senior Systems Architect
      Nissan Trading Corporation, Americas
      Lebanon, TN United States
      Chairman, Nashville (TN) GPUG Chapter
      GPUG Ruby Award 2018
      GPUG All Star 2017
      Twitter @SteveBurney
      GP2016 R2
      MRCU14
    • Shari Bruno
      February 6, 2019 at 11:36 AM
      ?Hi
      We have this issue because there are certain POs that are not put into History but we may never use the vendor again. Since we couldn’t mark these vendorsĀ Inactive due to being active on aĀ POĀ we created an “Inactive” vendor Class ID so we can use that as a sort. To prevent those vendors from being accidentally used, we change the Name, Short Name and Check Name to INACTIVE.
      Shari Bruno
      Accounting Operations Manager
      Bible League International
      Crete, IL
    • Jennifer Wheeler
      February 7, 2019 at 9:03 AM
      Hi Tammy
      Have you run the Remove Completed Purchase Orders routine?Ā  Below is a screen shot of the window.Ā  You could run it by Document Date and it will move the completed PO’s to history.Ā  I would try that to see if it helps with your vendor issue.
      GP-Remove PO
      Jennifer Wheeler
      Applications Solutions Administrator
      Dairy Farmers of America
      East Syracuse NY
    • Tammy Harper
      February 7, 2019 at 10:59 AM
      Jennifer,
      Thank you so much! That worked and now I’m getting our Vendor List cleaned up! This was something we didn’t know anything about, so needless to say we will be running it periodically from now on. How often do you run it?
      Thanks again!!
      Tammy Harper |  Accounts Payable Tech
      Punta Gorda Airport (PGD)
      28000 A-1 Airport Road
      Punta Gorda, FL 33982
      Office: 941.639.1101 ext: 139
      Email:
      tharper@flypgd.com
      NOTICE: This communication may contain confidential and privileged information that is for the sole use of the intended recipient. Any viewing, copying or distribution of, or reliance on this message by unintended recipients is strictly prohibited. If you have received this message in error, please notify me immediately by phone, fax or e-mail.
      Email: tharper@flypgd.com
      ——Original Message——
      Hi Tammy
      GP-Remove PO
      Jennifer Wheeler
      East Syracuse NY
    • Jennifer Wheeler
      February 7, 2019 at 2:35 PM
      Hi Tammy
      We run the Remove Completed Purchase Orders once a month.Ā Ā
      Jennifer Wheeler
      East Syracuse NY
    Tammy Harper replied 7 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Inactivate Vendors’ is closed to new replies.
