In the Select Payables Checks window choose just the Comcast vendor, and at the drop down that states “One Check Per” choose “invoice” which will create an individual check for each invoice. Then go back and enter the criteria for the remainder of the batch as One Check Per: Vendor. The Build Batch icon will state “Add to Batch” and you will get a message stating there are current records in the batch after you click on it. Choose “continue” and allow the rest of the payments to populate.
—————————— Shari Bruno Accounting Operations Manager Bible League International Crete, IL —————————— ——————————————-
Mary Sisley
December 13, 2017 at 11:06 AM
?Hi Jeanette:
We have the same issue with Verizon, so I have set up Verizon 1, Verizon 2, etc. that way separate checks are issued on the same batch.
Hope this helps.
—————————— Mary Sisley Accountant Accounts Payable Axis Health System Durango CO —————————— ——————————————-
You may want to try the “One Check Per: Invoice” option I mention above. It allows multiple checks to one vendor without having to create multiple vendor records for the same payee.?
