HITB Reset setup issues
  • HITB Reset setup issues
    Posted by Jeff Roe on June 13, 2020 at 1:15 am
    • Jeff Roe
      June 13, 2020 at 1:15 AM
      I’m installing and using the HITB reset tool for the first time. I have run the inventory reconcile and then the data checks.
      I had several errors that I have corrected but still have remaining (Open layer exists in purchase receipts table where valuation method not stamped).
      according to the documentation, as long as all other errors are correct theĀ Open layer exists in the purchase receipts table where the valuation method not stamped message should be systematically corrected and then allow the system to proceed to the next step.
      It still will not allow the HITB reset tool in GP to proceed even though theĀ  (Open layer exists in purchase receipts table where valuation method not stamped) is the only error remaining.
      Did I read something wrong?
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Samantha Higdon
      June 15, 2020 at 9:11 AM
      Hi ,
      The HITB reset toolĀ  generally does correct this issue.Ā  However, the KB article below doe provide some guidance on when it wouldn’t correct and some options on how to proceed.
      https://support.microsoft.com/en-us/help/2511801/you-receive-the-error-open-layer-exists-in-purchase-receipts-table-whe
      Have you taken a look at this KB article?Ā  If not, I’d start there.
      Samantha
      Samantha Higdon ,CPA,CGMA
      Consultant
      Lagom, LLC
      Carmel IN
    Jeff Roe replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘HITB Reset setup issues’ is closed to new replies.
