Help with Batch whose Status is ‘Posting Interrupted’ please “A save operation on table ‘PM_Transaction_OPEN’ has created a duplicate key.
  • Help with Batch whose Status is ‘Posting Interrupted’ please “A save operation on table ‘PM_Transaction_OPEN’ has created a duplicate key.
    Posted by DSC Communities on November 4, 2021 at 2:25 pm
    • Angela Morehouse
      November 4, 2021 at 2:25 PM
      I”m in a bad maze and feel there is a tiny way out, but I can’t find it. Batch recovery continually states ‘Process Interrupted’.Ā
      Initial error window:
      Batch recovery does nothing. I have researched and even tried running Checklinks, which found no errors. In the SY00500 table, I flipped BCHSTTUS to 0, was set to 7 in my initial investigation. Upon flipping to 0 and trying to reprocess it sets back to 7. Tried the processes again, nothing.Ā
      I was able to open up the batch somehow and the edit list shows the below. Can anyone shed light on the below messages? The user cannot edit the transactions as it states to use the batch recovery, but that is a bad loop I get into.Ā
      they show up in Financials > PMTRX
      SQL data
      Select * from DYNAMICS..SY00800 – No data
      Select * from DYNAMICS..SY00801 – No data
      Select * from TEMPDB..DEX_LOCK – No data
      Select * from TEMPDB..DEX_SESSION – No DEX row for this data/batch
      Please help me get out of this bad loop.
      Angela Morehouse
      CC Industries
      Chicago IL
    • Angela Morehouse
      November 4, 2021 at 3:22 PM
      Adding that I do see the transactions in the following tables; PM10000 (–Work/Unposted Transactions, PSTGSTUS of 20 – saved and unposted transaction), PM10100 (–GL Distributions for Work and Open Transactions, and PSTGSTUS of 1, which is unposted), and PM20000 (–Open/Posted Transactions PSTGDATE with a date back in October).Ā  Any insight?
      Angela Morehouse
      CC Industries
      Chicago IL
    • Angela Morehouse
      November 4, 2021 at 5:07 PM
      I was at a loss, so I had the user delete and start over fresh. I flipped BCHSTTUS to 0, was set to 7 initially, and went into some transactions, poked around, and saved to get the batch to open back up.Ā  It appears to have worked. I’m hoping there are no orphaned records that decide to cause an issue down the road.Ā
      Have a great day!
      Angela Morehouse
      CC Industries
      Chicago IL
    • David Musgrave
      November 5, 2021 at 1:06 AM
      This article might have helped identifying the duplicates.
      https://winthropdc.wordpress.com/2008/12/04/identifying-duplicate-transactions/
      Regards
      David?
      Managing Director
      Perth, Western Australia
      http://www.winthropdc.com
    DSC Communities replied 4 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Help with Batch whose Status is ‘Posting Interrupted’ please “A save operation on table ‘PM_Transaction_OPEN’ has created a duplicate key.’ is closed to new replies.
