GP2018 Summary Posting to GL
  • GP2018 Summary Posting to GL
    Posted by Thomas Hill on February 27, 2025 at 11:40 am
    We upgraded to GP2018 to start the new year. During the month of January, a posting setting was switched from Detail to Summary. This affected the batches posted from Payables and Receiving.
    I know manually I can drill down on the Journal Entry to see the detail. Did that. But since February was done this way for the whole month, I need to see if I can find the table that has the details.
    I use FileMaker Pro, to access GP tables (read-only). So I am comfortable doing this. I do not know if it is a PMXXXXX table or GLXXXXX table. Any help would be appreciated.
    Thomas Hill replied 11 months, 3 weeks ago 4 Members · 8 Replies
  • 8 Replies
  • Elaine Salyer
    February 27, 2025 at 12:00 pm
    Did you try Table Finder in GP?
    Microsoft Dynamics GP – Tools – Table Finder
    • Thomas Hill
      February 27, 2025 at 1:32 pm
      No. For all of the tables in GP2018, I am not sure if I am looking FINANCIAL or PURCHASING.
      I have used the table listing from Victoria Yodin’s website. That has helped me tremendously in the past.
  • David david@winthropdc.com
    February 27, 2025 at 11:23 pm
    Hi Thomas
    First of all, posting in summary is a legacy feature which goes back to the days when hard disk space was expensive. I would never recommend that nowadays as it makes it very difficult to reconcile GL to subsidiary modules such as RM/SOP and PM/POP.
    History data for the PM module should be found in the PM_Paid_Transaction_HIST (PM30200) table and PM_Distribution_HIST (PM30600) table.
    History data for the POP module should be found in the POP_ReceiptHist (POP30300) table and the POP_ReceiptLineHist (POP30310) table along with the POP_DistributionHist (POP30390).
    Finally, The Table Finder is a tool in SmartList Builder and not available to all installs. In the same way GP Power Tools Resource Information and Resource Finder windows are only available from the Tools menu if the product is installed.
    Hope this helps
    David
  • Thomas Hill
    February 28, 2025 at 10:33 am
    When I joined this company they were on GP2010, then upgraded to GP2015. Everything has been detail posted during the time. We upgraded to GP2018 to start January. Reviewing the data, the detail was posted until mid-month. Then a change put it at summary. January finished in summary and all of February has been summary posted. There was a change from GP2015 to GP2018 on the posting parameters. Automatically posting payables and receivables to the general ledger did not work as the settings from GP2015 were.
  • Thomas Hill
    February 28, 2025 at 11:19 am
    @WinthropDC Thanks for those table references. You do not happen to know if there is a GL_table with fields for the JRNENTRY and the BATCHNUM from the module? GL20000 does not have it as such.
    • Amber Bell
      March 19, 2025 at 3:15 pm
      Hello Thomas, I worked with Microsoft Copilot to create a SQL View to help you! I included all 10 Account segment columns. You can edit that out:
      SELECT
          PM10100.TRXSORCE AS [Transaction Source],
          PM10100.VCHRNMBR AS [Voucher Number],
          PM10100.VENDORID AS [Vendor ID],
          PM10100.DEBITAMT AS [Debit Amount],
          PM10100.CRDTAMNT AS [Credit Amount],
          GL00100.ACTDESCR AS [GL Account Description],
          RTRIM(
              ISNULL(RTRIM(GL00100.ACTNUMBR_1) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_2) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_3) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_4) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_5) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_6) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_7) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_8) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_9) + '-', '') +
              ISNULL(RTRIM(GL00100.ACTNUMBR_10), '')
          ) AS [Account Number]
      FROM PM10100
      JOIN GL00100 ON PM10100.DSTINDX = GL00100.ACTINDX
      UNION ALL
      SELECT
          PM30600.TRXSORCE AS [Transaction Source],
          PM30600.VCHRNMBR AS [Voucher Number],
          PM30600.VENDORID AS [Vendor ID],
          PM30600.DEBITAMT AS [Debit Amount],
          PM30600.CRDTAMNT AS [Credit Amount],
          RTRIM(
      FROM PM30600
      JOIN GL00100 ON PM30600.DSTINDX = GL00100.ACTINDX;
      • Amber Bell
        March 19, 2025 at 3:32 pm
        Down Accepted answer
        I thought you might want the Journal Entry number and date. I added that table. I limited it to just pull the first journal entry number and then create a column to let you know how many journal entries are part of that Transaction Source. Also…I made a query…not a view. If you need it as a view, let me know.
        WITH GLData AS (
            SELECT
                ORGNTSRC,
                JRNENTRY,
                TRXDATE,
                ROW_NUMBER() OVER (PARTITION BY ORGNTSRC ORDER BY TRXDATE) AS rn
            FROM GL20000
        SELECT
            RTRIM(
            ) AS [Account Number],
            GLData.JRNENTRY AS [Journal Entry],
            GLData.TRXDATE AS [GL Trx Date],
            (SELECT COUNT(DISTINCT JRNENTRY) FROM GL20000 WHERE ORGNTSRC = PM10100.TRXSORCE) AS [Unique Journal Entry Count]
        FROM PM10100
        LEFT JOIN GLData ON PM10100.TRXSORCE = GLData.ORGNTSRC AND GLData.rn = 1
        UNION ALL
        SELECT
            RTRIM(
            (SELECT COUNT(DISTINCT JRNENTRY) FROM GL20000 WHERE ORGNTSRC = PM30600.TRXSORCE) AS [Unique Journal Entry Count]
        FROM PM30600
        LEFT JOIN GLData ON PM30600.TRXSORCE = GLData.ORGNTSRC AND GLData.rn = 1;
        • Thomas Hill
          March 20, 2025 at 2:08 pm
          Thank you for the WORK you did. However, I got the data I needed for Jan and Feb. March started with summary posting turned off.
