GP Printing Issues After Upgrading to Windows 11
  • GP Printing Issues After Upgrading to Windows 11
    Posted by Jennifer Wheeler on May 29, 2024 at 8:54 am
    We use a Report Writer report for our purchase order and in Report Writer we have the page orientation set to print as landscape. Now after upgrading to Windows 11 the POs are printing out as portrait. The printer settings is set to default to portrait but it was that way before upgrading to Windows 11 and the POs printed as landscape. I don’t want to default the printer setting to landscape. Has anyone else seen this issue after upgrading to Windows 11?
    Donny Kensmoe replied 1 year, 1 month ago 4 Members · 4 Replies
  • 4 Replies
    May 29, 2024 at 2:09 pm
    Hi @Jennifer Wheeler
    Have you updated all of your printer drivers?
  • Jennifer Wheeler
    May 30, 2024 at 12:08 pm
    Thanks for the reply Jo. I was searching online and believe I found the issue. It seems with Windows 11 newer print dialog if you have a custom report that is set to print in landscape it will ignore that and default to print in portrait. So, every time you print you have to either manually change it to print in landscape each time or you can restore the legacy print dialog by making registry setting change.
    • David david@winthropdc.com
      August 28, 2024 at 10:49 pm
      GP Power Tools restores the legacy print dialog by default as the new dialog does not work well with GP.
      It is an option that can be changed on the Dex.ini Settings window.
  • Donny Kensmoe
    February 12, 2025 at 11:47 am
    @David Musgrave what is the dex.ini switch I can add to accomplish this?
