We just used GPPT as our platform for a recent and simple customization, it worked so well that I feel the need to share.
For some that are already using VST, VBA, etc, it’s likely a matter of preference but for those that don’t have a ton of customizations scaled out already, I’d highly recommend consider doing them within GPPT.
– Customizations stay super visible (just a separate tab–>window in GP versus being more “behind the scenes”) – Capabilities are almost endless – Simple implementation (Basically turn it off/on from a window within GP) – The logic itself is similar to what you’d see in other customization tools so on-going support options should be the same
Again, just a great & simple experience from our end and something I’d highly recommend others considering in the future.
Customization itself was for fixed assets.Ā If/when an existing asset is changed, display a ‘Reason for Change’ window that then saves into the notes field associated with that asset.Ā This note provides the explanation that our reviewers and auditors need (and GP should prompt for out of the box but another story).
—————————— Kyle Malone, CPA GP Admin – CGB Enterprises, Inc. Lead Consultant/Blogger – http://ALaCarteGP.com Chapter Leader – Louisiana (New Orleans) ——————————
?GP Power Tools can be used to replace most VBA code using a combination of Dexterity, SQL, C# and VB.Net code without needing Dexterity, SQL Management Studio or Visual Studio loaded. There is no additional deployment steps needed and no upgrade steps needed other than testing. Code written with GP Power Tools is web client compatible.
Code can be written in a test environment and then just exported and imported in a live environment.Ā Changes are active immediately after saving and take effect on next login or company switch.Ā Code can be easily limited on a per user, per company or per user and company basis.
Why don’t you try it out? Just install and activate the free 30 day trial period for all the modules.
Regards
David
—————————— David Musgrave MVP, GPUG All-Star
Managing Director Winthrop Development Consultants
