GP Financials in Excel
  • GP Financials in Excel
    Posted by reneeanter@alternativehomehealth.com on February 23, 2017 at 8:50 am
    • Renee Anter
      February 23, 2017 at 8:50 AM
      HI Everyone and thanks for looking at my information request.
      Can anyone share with me any Balance Sheet and P&L Reports in Excel that connected to GP that can be customized that look anything like those available with JetReports?
      Ernesto Rivero
      Alternative Home Health Care
      Tamarac FL
    • Scott White
      February 23, 2017 at 10:01 AM
      Ernesto, are you aware that Jet Reports has a Jet Express for Excel available for free that links into MSDGP databases?  I do not know which Jet reports you are referring to but if the Jet Reports are using the Jet function supported in Jet Express the reports will work.
      Scott White
      Little Rock AR
    • Renee Anter
      February 23, 2017 at 2:59 PM
      thanks for the info scott
      Ernesto Rivero
      Tamarac FL
    • Curt Bluhm
      February 24, 2017 at 8:12 AM
      Ernesto,
      I use Microsoft Query in Excel to establish a live link to the GL tables in Excel.  I’ve been able to create all the normal financial statements, balance sheet, income statements, cash flow as well as some dynamic statements where I’m looking at by month P & L lines where I pick up the actuals for the months thru the month of my choosing then the budgeted amounts for the months for the remaining portion of the year so I can see my projected numbers thru the end of the year.
      I use the item card user defined fields to help with this as well as the item categories.
      The fun part of this is the ability to change the month on the statements and all the statements update so it’s a very dynamic report.  Because it’s in excel, you can also build on it if you need too.
      I’d be happy to discuss offline it you’d like.  Too much information to get into in this blog.
      Curt Bluhm
      CFO
      ADO Products LLC
      Plymouth MN
    • Darryl Turner
      February 27, 2017 at 10:44 AM
      Not sure exactly what you are looking for, but I can tell you that at Nuna Logistics they have used F9 for 21 years to do statements in Excel.  F9 is an Excel add-in that gives you Excel functions that pull directly from the GP databases – Summary amounts, GL transactions with full details available, and Budget.  It has also had Budget write-back capabilities all this time whereas Excel-based budgeting has only been around for half as long.  Its an inexpensive product that is very stable and easy to learn. F9 | Financial Reporting in Excel
      F9 remove preview
      F9 is an easy-to-use financial reporting tool that dynamically links general ledger data to Microsoft Excel and is available for over 150 different accounting and ERP systems. Everything you know about spreadsheets can be applied to the reports you create using F9.
      View this on F9 >
      Darryl Turner
      I.T. Manager
      Nuna Logistics Limited
      Edmonton AB
The discussion ‘GP Financials in Excel’ is closed to new replies.
