GP 2018 allowing users other than sa to manage accounts
  • GP 2018 allowing users other than sa to manage accounts
    Posted by Carl Meyer on October 5, 2018 at 8:53 am
    • Carl Meyer
      October 5, 2018 at 8:53 AM
      Before 2018, I was able to manage GP accounts including deleting active with my GP account and not sa with the tips in this mink:Ā Create GP Users without using ‘sa’
      DynamicAccounting.net remove preview
      A while back at a conference Nicole Albertson of eOne and I were talking about not using the ‘sa’ user and using a different GP user to create users. She brought up the central point of this piece, but I can’t find that she ever wrote about it.
      View this on DynamicAccounting.net >
      However now it seems I can not delete user activity with my personal account, I must use sa instead.Ā  Did something change with GP 2018 with user security?
      Carl Meyer
      Forge Resources Group
      Dekalb IL
    • Carl Meyer
      October 5, 2018 at 12:13 PM
      ?Please note I have the sysadmin role in SQL already.Ā Ā I double checked that prior to posting.
      Carl Meyer
      Dekalb IL
    • Jen Kuntz
      October 8, 2018 at 8:14 AM
      Hi Carl,
      Nothing there has changed and I just tested myself, with a non-sa sysadmin-in-SQL GP login and there was no issue removing someone from User Activity.
      The only thing I would clarify that you check – in the off-chance that there’s a misunderstanding – is to make sure it’s your GP login in SQL that has the sysadmin server role, not your Active Directory domain user.
      If you believe that’s correct, perhaps post screen shots here of the SQL user on the Server Roles setting and the same user in User Setup in GP and maybe we can see something from that that might explain the issue.
      Jen
      Jen Kuntz, CPA, CGA, Microsoft MVP (Business Applications)
      Manager, Business Solutions
      Energy+ Inc.
      Cambridge, ON, Canada
    • Mark Polino
      October 8, 2018 at 10:46 AM
      You said that you are a sysadmin in SQL so assuming that you still have the same rights in GP, there’s shouldn’t be a normal reason that you can’t delete users.Ā
      I’ve seen some cases with user corruption (generally, not specific to 2018 R2). GP is essentially just passing the delete request to SQL, but sometimes odd things happen. Try creating a test user and deleting it. If that works, it’s an issue with specific user accounts, not your security in general. You can also try deleting directly from SQL as a test.
      Mark
      Mark Polino
      Director of Client Services
      Fastpath
      Altamonte Springs FL
    • Carl Meyer
      October 11, 2018 at 4:47 PM
      Please see attached screenshots.Ā  I have the server role sysadmin, but my user activity window does not have the delete button.
      I would assume GP is looking for something when generating that window to determine if I can delete user’s Activity or not.
      I can modify users in the user setup, add and create users, assign security.Ā  So it seems just can’t delete activity?
      My Security roles in GP include PowerUser, so I think I am good on that front.
      Carl Meyer
      Dekalb IL
    • Jen Kuntz
      October 11, 2018 at 5:06 PM
      Hi Carl,
      The Activity window looks normal to me. The delete button is beside the OK button, and doesn’t appear to be disabled (visually). Are you saying once you click on a user name in the activity list, that Delete button disappears?
      Jen
      Energy+ Inc.
    • Carl Meyer
      October 12, 2018 at 8:58 AM
      I just changed my settings to use the ribbon after for a long time using the old screens.Ā  Figured I should not send screenshots that don’t match my users šŸ™‚
      The Ribbon screen moved Delete to the ribbon and I was looking for the button on the bottom of the screen.
      Carl Meyer
      Dekalb IL
    • Jen Kuntz
      October 12, 2018 at 10:39 AM
      Glad you’ve got it figured out. Sometimes we can’t see the forest for the trees! šŸ™‚
      Jen
      Energy+ Inc.
    Carl Meyer replied 8 years ago 1 Member · 0 Replies
The discussion ‘GP 2018 allowing users other than sa to manage accounts’ is closed to new replies.
