GP 2016 R2 Web Client – Stuck on Sign-in
Posted by David Morinello on March 28, 2017 at 5:17 pm-
Can anyone help me past this latest sticking pointing in a new test install of the GP 2016 R2 Client.
– Scaled-out with one Web Client Server and one Session Server.
– No Certificate errors for the SessionCentralService or SessionService URLs
– All services are running.
– All restarted.
– IIS Reset
– Domain Account (and local server admin) for the GP Session Central Service on the Web Client Server
– Domain Account (and local server admin) for the GP Session Services Service on the Session Server——————————
David Morinello
Ascend Learning, LLC
Leawood KS
Well, there were no Event logs errors last night while looking at that Web Client screen hang, but this morning I see errors in both the Web Server’s Dynamics Event log, and in the Session Server’s Dynamics Event log.
I do not know what more right’s I can give to this AD account on the two servers. Is there something missing in how the AD account was created, or am I missing some step on the two servers?
Web Client
This errors 8 times. No pattern I can see to the time spacing. 4 in the 4pm hour, 2 in the 5 pm hour, skip to 1 in the 9pm hour and 1 in the 10 pm hour. all while I was offline.
Source:Microsoft.Dynamics.GP.Web.Services.SessionCentralServiceAn unauthorized attempt to call the ReportSessions operation on Session Central was made by domainxxxxxxx. (Note, this is a Domain Account and local server admin) for the GP Session Central Service on the Web Client Server)
Session Server
Source: Microsoft.Dynamics.GP.Web.Services.SessionService
An error occurred during session monitoring: ‘System.ServiceModel.FaultException`1[System.ServiceModel.ExceptionDetail]: The user is not authorized to call this service operation. (Fault Detail is equal to An ExceptionDetail, likely created by IncludeExceptionDetailInFaults=true, whose value is: System.InvalidOperationException: The user is not authorized to call this service operation. at Microsoft.Dynamics.GP.Web.Services.Session.Service.SessionCentralService.ValidateCallerIsMemberOf(String principalCollectionKey) at Microsoft.Dynamics.GP.Web.Services.Session.Service.SessionCentralService.ReportSessions(SessionHostStatus sessionHostStatus, IEnumerable`1 sessionsToReport) at SyncInvokeReportSessions(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperati…).’.——————————
David Morinello
Leawood KS
Beat Bucher
MemberMarch 30, 2017 at 8:21 AM
Hi David,
might be a shot in the dark, but make sure the service account you’re running the GP Web service has proper policy permissions on the server (logon as a service and/or logon locally)..——————————
Beat Bucher
Montreal QC/Canada
+1-514-489-4267
GP2013R2 / MR2012 CU14
I have asked the question and others of our network people, but have not heard back yet.
In the mean time, I did a complete uninstall of the web pieces on both the Session Host and Session Server, removed the database, then reinstalled all. Still I get various errors related to that one AD account.
- An unauthorized attempt to call the GetWebsiteSecurityGroups operation on Session Central was made by AXXXXXXASC-xxxxxx.
- An unauthorized attempt to call the ReportSessions operation on Session Central was made by AXXXXXXASC-xxxxxx.
- An unauthorized attempt to call the GetActiveSessionsForAllUsers operation on Session Central was made by AXXXXXXASC-xxxxxx.
Before I can open a ticket on this, I am supposed to exhaust all other avenues in-house. I might be there now.
David Morinello
Leawood KS
Beat Bucher
MemberApril 3, 2017 at 8:01 AM
David,
Did you start the Web installl with a brand new SQL database ? this had bit me in past as I had issues with re-installing or upgrading the web client, and I was told by Mariano to just delete the existing Web client DB and create a new one.. Worked on the 1st shot.——————————
Beat Bucher
Montreal QC/Canada
+1-514-489-4267
I started from scratch on Friday and am still running into some kind of access issue. My Domain guy says the AD account is set correctly
I did a complete uninstall, cleanup and reinstall of the pieces and still see errors related to that AD account. New DB.
– an unauthorized attempt to call the GetWebsiteSecurityGroups operation on Session Central was made by
AXXXXXXASC-xxxxxx.
– An unauthorized attempt to call theReportSessions operation on Session Central was made by AXXXXXXASC-xxxxxx
– An unauthorized attempt to call theGetActiveSessionsForAllUsers operation on Session Central was made by
AXXXXXXASC-xxxxxxIs there anything in these “operations” that might point me in the right direction?
I am diving into SysInternals tools now. Process Explorer drilled to “Microsoft.Dynamics.GP.ServiceHost.exe” shows User as <access denied>.
Again, to test, this AD account is set up in both the Web Client & Session servers as a local Admin, on the SQL server as sysadmin.
David Morinello
Leawood KS
David Morinello replied 9 years, 8 months ago 1 Member · 0 Replies -
The discussion ‘GP 2016 R2 Web Client – Stuck on Sign-in’ is closed to new replies.
