Fixed Assets General Ledger Zoom
  • Fixed Assets General Ledger Zoom
    Posted by DSC Communities on September 26, 2017 at 1:02 pm
    • Sharon Hine
      September 26, 2017 at 1:02 PM
      ?Hello,
      I am looking for a report or Smartlist configuration that willĀ provide the dataĀ in the Fixed Assets General Ledger Zoom window (see below).Ā
      I need to start with the FATRX batch and summarize by Asset ID to determine whether the correct depreciation has been taken for each asset.Ā  We have a Fixed AssetsĀ expenseĀ GL anomaly that cannot be explained by any of our direct entries – so something must be off with one of the FATRX depreciation transactions.
      Thanks for any help you can give,
      Sharon
      FA General Ledger Zoom
      Sharon Hine
      Manager, Program and Financial Systems
      CANARIE Inc
      Canada
    • Matthew Arp
      September 26, 2017 at 1:12 PM
      I would try this SL configuration and see if it provides you with what you need.
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • James Hummer
      September 27, 2017 at 4:39 PM
      ?Hey Sharon
      You can also use BI360 in which we just added a FA to GL Reconcile View.Ā Ā  Note BI360 Report Composer is now Free.Ā Ā Ā  Just sign up here.Ā Ā Ā
      https://register.gotowebinar.com/register/1997299541128818691
      Dynamics GP FA to GL Reconcile – Community Forums
      Solverglobal remove preview
      View this on Solverglobal >
      Jim Hummer
      Consultant
      Solver
      Los Angeles CA
    • Windi Epperson
      September 26, 2017 at 5:16 PM
      Sharon,
      If you’re looking at specific assets, then maybe start with the InquiryFinancial Detail window.Ā  You can set some parameters in there and then when you print you get a decent report by asset.
      If you’re looking for a group of assets, then you might try the FA to GL reconcile report.Ā  It’s under FinancialReportsActivityFixed Assets to General Ledger Reconciliation.Ā  You can put date and asset parameters on it if you’d like.
      Windi
      Windi Epperson
      Advanced Integrators, Inc.
      Norman OK
      405-946-1774 Ext 102
    • Sharon Hine
      September 27, 2017 at 11:57 AM
      ?Thank you all.Ā  Your suggestions helped meĀ find the problem.
      Cheers,
      Sharon
      Sharon Hine
      CANARIE Inc
      Canada
    • Kimberly Lomax
      September 27, 2017 at 2:02 PM
      Glad you found your issue. Ā We have a SmartList that we use quite a bit when researching the GL transactions. Ā You may find it useful for future reference.
      Shows tables used in showing all GL details from the FA module.
      Kimberly Lomax
      Manager, Financial Systems
      Rayonier
      Jacksonville FL
    DSC Communities replied 8 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Fixed Assets General Ledger Zoom’ is closed to new replies.
