Extender data in a SmartList or SSRS report
  • Extender data in a SmartList or SSRS report
    Posted by Howard Blitstein on May 20, 2025 at 11:04 am
    A previous admin created some Extender Forms/Windows that have been used extensively. A user is asking me how can they see the data that has been entered. A smartlist that was created is not capturing all the data. I haven’t used Extender a lot, so I am a bit lost. I do see there is the Navigation option on the Form and to link it to Smartlist. Not 100% sure what the next steps are. If there is an better SSRS option I am good with that, but just can’t see what SQL tables is holding the data from these windows.
    thx
    David david@winthropdc.com replied 9 months, 2 weeks ago 3 Members · 3 Replies
  • 3 Replies
  • Devon Southall
    May 23, 2025 at 9:52 am
    ok – there is a lot here. first – there is some functionality in extender to add fields to smartlists -but I don’t use it because I find it slows it down a LOT.
    Extender has the ability to build views with the data from its windows/forms. That is the best way to access the data.
    Then you use Smartlist builder or designer to join in the view to see.
    Do you have access to the Extender manuals – that should walk you thru how to add the view.
  • David david@winthropdc.com
    May 25, 2025 at 9:47 pm
    Hi Howard
    Also have a look at this article I wrote about creating views for extender data. These views can then be joined with other tables/views to create a new view and then added as a smartlist based on a SQL View.
    https://winthropdc.wordpress.com/2009/02/05/creating-sql-views-of-extender-data/
    Good luck
    David
    May 25, 2025 at 9:58 pm
    PS: I believe that the views as created in my article are better than the views created by extender as they better handle when data is missing.
