Error at the Calculate Check step during Payroll run
  • Error at the Calculate Check step during Payroll run
    Posted by Brian Heiple on December 30, 2019 at 5:58 pm
    • Brian Heiple
      December 30, 2019 at 5:58 PM
      After applying the year end update to my Dynamics GP 2015 R2 Test system I am encountering the error below at the Calculate Checks step during a pay run.
      The complete error message is …  Ā  Ā Ā
      Unhandled Script exception:
      SCRIPTS – data area
      EXCEPTION_CLASS_SCRIPT_ADDRESSING
      SCRIPT_CMD_LOAD
      Any thoughts on where to start to trouble shoot this one?
      Brian Heiple
      Sr Application Analyst
      Lutheran Social Service of Minnesota
      Saint Paul MN
    • Mark LeRette
      December 31, 2019 at 9:27 AM
    • Brian Heiple
      December 31, 2019 at 9:48 AM
      Mark,
      I did see Terry’s post and I don’t find the results she notes in the post also the message I getting is slightly different.
      Brian Heiple
      Saint Paul MN
      December 31, 2019 at 9:32 AM
      Can you scroll down and see if there is more to this message?Ā  There usually is.Ā  That is where we’d find more info in order to help.?
    • Brian Heiple
      December 31, 2019 at 9:55 AM
      Hi Jo,
      The complete message is below.Ā
      SCRIPTS – data area
      SCRIPT_CMD_LOAD
      Brian Heiple
      Saint Paul MN
    • Dawn Schwarz
      December 31, 2019 at 9:42 AM
      Brian
      I am not sure that I have run across that error but I have had many people say they can’t calculate checks for 2020 after building the year-end wage file for 2019.Ā  When they set the system date to 2020 the checks calculate fine.Ā  Worth a shot I guess but not sure it is the same issue.
      Dawn
      Dawn Schwarz
      Senior Consultant
      Wipfli
      Madison WI
    • Nick Rodriguez
      January 28, 2020 at 11:54 AM
      Hi Brian,
      Did you ever come up with a solution to this? We just started getting this error when calculating checks (after installing the 2019 YE update), but it doesn’t seem to happen with every check run for some reason. Trying to figure out what it might be in the batches that won’t calculate that’s causing it. Thanks!
      Nick Rodriguez
      ATC Healthcare Services
    Brian Heiple replied 6 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Error at the Calculate Check step during Payroll run’ is closed to new replies.
