Emailing standard GP SOP documents versus Word Templates
Posted by kathy.kim@dnaz.org on November 8, 2017 at 8:45 am-
I have read conflicting information regarding emailing standard (but modified) SOP documents versus Word Templates.Ā I have read on this site that you can only email SOP invoices if they use Word Templates, but I have also read that others are emailing modified SOP forms that are not Word Templates.Ā We would prefer not to modify all of our existing documents as word templates if we don’t have to (and will likely move to a 3rd party product rather than do so).Ā However, if we can email our original SOP invoice format, we will likely stick with what we have.Ā Thank you for any clarification you can provide.
Kathy Kim
Director of Finance
Donor Network of Arizona
Phoenix AZ
Rob Klaproth
MemberNovember 9, 2017 at 1:45 AM
Hi Kathy,You can email individual invoices to the customer by printing the invoice to the screen and then selecting email.Ā When you do this, it will email the default format of the report to them.
However, when you use the GP mass email functionality, where you configure a document type such as Order on a customer and select an email address, these use the word templates.Ā Ā I have heard conflicting info that if you change their email type to HTML you can still email the standard report (not the template), but if you want them to get a PDF or DOC file then you’re forced to use the templates.
Rob Klaproth
(GP Install & Configure)
Sr. GP Consultant
Armanino, LLP
San Diego, CA
Beat Bucher
MemberNovember 9, 2017 at 10:32 AM
Hi Kathy,
Please note that Rob’s suggestion to e-mail the on-screen report is not the most elegant one, as it just attaches a .TXT file to the e-mail, which sometimes looks pretty weird..
However, if you have Acrobate Writer installed, GP will recognize the fact and also allow you to e-mail the report in PDF format straigt out of GP.. but this involves to pay for the a full Acrobat license..Our purchasing department does print all POs for example as PDF files and mails them to the vendor in a separate process.. not straight out of GP. The same can be applied to the SOP processing.. The advantage is that you’re not bound to use Acrobate Writer (which is rather expensive), but can use any little software that can produce PDF format (like PDFCreator which is even free).
Beat Bucher
Montreal QC/Canada
GP2013R2 / MR2012 CU14
Thanks Beat – we have recently started emailing the invoices using the procedure above, but that requires emailing one by one (at least I think so).Ā I haven’t been able to check out the whole process yet since we got the Adobe piece working again – we had the licensing, but had some issues where the Adobe invoices wouldn’t print.Ā Turned out it was a simple setting. I would like to be able to email the batch by setting up the email addresses within GP and then select email rather than print.Ā I think you can do with GP functionality without purchasing 3rd party software, but I’m not sure.Ā Ā Our partner has recommended a 3rd party product which we are looking at, but just trying to see what we can do with the existing functionality before we go that route.
Kathy Kim
Director of Finance
Phoenix AZ
Thanks Rob, that’s good information!Ā I will check out that HTML option!
Kathy Kim
Director of Finance
Phoenix AZ
Hi Kathy,
Please feel free to take a look at Liaison Messenger EDD by Liaison Software.
Messenger EDD allows you to use your existing GP report writer reports and batch email, batch fax, archive, and attach both static and variable attachments.Ā
It emails out using one of the following – Outlook, Office 365, SMTP, or Gmail.
For more information and additional features please view our website:
Liaison Messenger EDD email from Dynamics GPIf you have any questions or would like to schedule an on-line demonstration please reach me at 800.811.4618 x201.
Thomas Nielsen
Sales Manager
Liaison Software Corporation
Santa Ana CA
714-543-9877 x201
tom@liaisonsc.com
Christine Boisvert
MemberNovember 9, 2017 at 11:05 AM
We use Liaison Messenger to email our customer invoices and customer statements. It works very well. Their support department is very good and implementation is easy. Liaison works with any reports out of Dynamics (and any other documents for that matter). I would definately recommend this solution.——————————
Christine Boisvert
Floform Countertops
Winnipeg MB
Binary Stream’s eMailer Manager can email any SOP document in any format, as well as POs, EFTs, PA billings and Payroll reports. The cost for it would be less than modifying all your current templates!
Neil MacDonald
Solutions Consultant
Binary Stream
Moncton NB
kathy.kim@dnaz.org replied 8 years, 4 months ago 1 Member · 0 Replies -
The discussion ‘Emailing standard GP SOP documents versus Word Templates’ is closed to new replies.
