eConnect & 1099 Nonemployee Compensation (NEC) – Error 3396
  • eConnect & 1099 Nonemployee Compensation (NEC) – Error 3396
    Posted by Kyle Malone on January 22, 2021 at 10:46 am
    • Kyle Malone, CPA
      January 22, 2021 at 10:46 AM
      Hello GPUG!
      Anyone know how to update eConnect to start looking for Tax Type = 5 & not throw errors when importing / updating existing vendors that are set to 1099-NEC?
      Kyle
      Error Number = 3396Ā  Stored Procedure= taUpdateCreateVendorRcdĀ  Error Description = The Tax Type parameter is invalid: 1=Not a 1099 Vendor; 2=Dividend; 3=Interest; 4=Misc.
      Kyle Malone, CPA
      ?GPUG Allstar | Chapter Leader – Louisiana (New Orleans)
      Lead Consultant/Blogger – https://alacarteGP.com
      Solugence | Find the software that FITS your business + integrates with GP. https://solugence.com
    • Windi Epperson
      January 24, 2021 at 10:57 AM
      Hey
      I’m sure you know but eConnect hasn’t gotten an u?pdate in years.Ā  One work around option could be to import your 1099 folks with a type that isn’t used often – like Dividend – and then use the 1099 update utility in GP to swap them to NEC flags once imported.
      We can also tag to see if this is maybe in the plans for a future update?
      Windi
      Windi Epperson
      Customer Support Manager
      Njevity, Inc
      Norman OK
      720-870-9700 x104
    • Corey Clay
      January 24, 2021 at 1:01 PM
      Hi –
      We have addressed this with our clients by adding a bit of code to the post procedure for taUpdateCreateVendorRcd eConnect stored proc.? This has worked for us up to this point. Hope it helps for you and others.
      SET ANSI_NULLS ON
      GO
      SET QUOTED_IDENTIFIER OFF
      GO
      ALTER PROCEDURE [dbo].[taUpdateCreateVendorRcdPost] @I_vVENDORID CHAR(15)
      	,@I_vVENDNAME CHAR(64)
      	,@I_vVENDSHNM CHAR(15)
      	,@I_vVNDCHKNM CHAR(64)
      	,@I_vHOLD TINYINT
      	,@I_vVENDSTTS SMALLINT
      	,@I_vVNDCLSID CHAR(10)
      	,@I_vVADDCDPR CHAR(15)
      	,@I_vVNDCNTCT CHAR(60)
      	,@I_vADDRESS1 CHAR(60)
      	,@I_vADDRESS2 CHAR(60)
      	,@I_vADDRESS3 CHAR(60)
      	,@I_vCITY CHAR(35)
      	,@I_vSTATE CHAR(29)
      	,@I_vZIPCODE CHAR(10)
      	,@I_vCCode CHAR(6)
      	,@I_vCOUNTRY CHAR(60)
      	,@I_vPHNUMBR1 CHAR(21)
      	,@I_vPHNUMBR2 CHAR(21)
      	,@I_vPHNUMBR3 CHAR(21)
      	,@I_vFAXNUMBR CHAR(21)
      	,@I_vTAXSCHID CHAR(15)
      	,@I_vSHIPMTHD CHAR(15)
      	,@I_vUPSZONE CHAR(3)
      	,@I_vVADCDPAD CHAR(15)
      	,@I_vVADCDTRO CHAR(15)
      	,@I_vVADCDSFR CHAR(15)
      	,@I_vACNMVNDR CHAR(20)
      	,@I_vCOMMENT1 CHAR(30)
      	,@I_vCOMMENT2 CHAR(30)
      	,@I_vNOTETEXT VARCHAR(8000)
      	,@I_vCURNCYID CHAR(15)
      	,@I_vRATETPID CHAR(15)
      	,@I_vPYMTRMID CHAR(20)
      	,@I_vDISGRPER SMALLINT
      	,@I_vDUEGRPER SMALLINT
      	,@I_vPYMNTPRI CHAR(3)
      	,@I_vMINORDER NUMERIC(19, 5)
      	,@I_vTRDDISCT NUMERIC(19, 2)
      	,@I_vTXIDNMBR CHAR(11)
      	,@I_vTXRGNNUM CHAR(25)
      	,@I_vCHEKBKID CHAR(15)
      	,@I_vUSERDEF1 CHAR(20)
      	,@I_vUSERDEF2 CHAR(20)
      	,@I_vTEN99TYPE SMALLINT
      	,@I_vTEN99BOXNUMBER SMALLINT
      	,@I_vFREEONBOARD SMALLINT
      	,@I_vUSERLANG SMALLINT
      	,@I_vMINPYTYP SMALLINT
      	,@I_vMINPYDLR NUMERIC(19, 5)
      	,@I_vMINPYPCT NUMERIC(19, 2)
      	,@I_vMXIAFVND SMALLINT
      	,@I_vMAXINDLR NUMERIC(19, 5)
      	,@I_vCREDTLMT SMALLINT
      	,@I_vCRLMTDLR NUMERIC(19, 5)
      	,@I_vWRITEOFF SMALLINT
      	,@I_vMXWOFAMT NUMERIC(19, 5)
      	,@I_vRevalue_Vendor TINYINT
      	,@I_vPost_Results_To SMALLINT
      	,@I_vKPCALHST TINYINT
      	,@I_vKPERHIST TINYINT
      	,@I_vKPTRXHST TINYINT
      	,@I_vKGLDSTHS TINYINT
      	,@I_vPTCSHACF SMALLINT
      	,@I_vPMCSHACTNUMST VARCHAR(75)
      	,@I_vPMAPACTNUMST VARCHAR(75)
      	,@I_vPMDAVACTNUMST VARCHAR(75)
      	,@I_vPMDTKACTNUMST VARCHAR(75)
      	,@I_vPMFINACTNUMST VARCHAR(75)
      	,@I_vPMPRCHACTNUMST VARCHAR(75)
      	,@I_vPMTDSCACTNUMST VARCHAR(75)
      	,@I_vPMMSCHACTNUMST VARCHAR(75)
      	,@I_vPMFRTACTNUMST VARCHAR(75)
      	,@I_vPMTAXACTNUMST VARCHAR(75)
      	,@I_vPMWRTACTNUMST VARCHAR(75)
      	,@I_vACPURACTNUMST VARCHAR(75)
      	,@I_vPURPVACTNUMST VARCHAR(75)
      	,@I_vUseVendorClass TINYINT
      	,@I_vCreateAddress TINYINT
      	,@I_vUpdateIfExists TINYINT
      	,@I_vRequesterTrx SMALLINT
      	,@I_vUSRDEFND1 CHAR(50)
      	,@I_vUSRDEFND2 CHAR(50)
      	,@I_vUSRDEFND3 CHAR(50)
      	,@I_vUSRDEFND4 VARCHAR(8000)
      	,@I_vUSRDEFND5 VARCHAR(8000)
      	,@O_iErrorState INT OUTPUT
      	,@oErrString VARCHAR(255) OUTPUT
      AS
      SET NOCOUNT ON
      SET TRANSACTION ISOLATION LEVEL READ UNCOMMITTED
      IF @I_vTEN99TYPE = 4
      	AND @I_vTEN99BOXNUMBER = 7
      BEGIN
      	SELECT @I_vTEN99TYPE = 5
      		,@I_vTEN99BOXNUMBER = 1
      	UPDATE PM00200
      	SET TEN99TYPE = @I_vTEN99TYPE
      		,TEN99BOXNUMBER = @I_vTEN99BOXNUMBER
      	WHERE VENDORID = @I_vVENDORID
      	IF (@@error <> 0)
      	BEGIN
      		SELECT @O_iErrorState = 993
      		RETURN (@O_iErrorState)
      	END
      END
      SELECT @O_iErrorState = 0
      GO?
      Corey Clay
      Senior Technical Consultant
      NexTec Group
    • Kyle Malone, CPA
      January 26, 2021 at 12:28 PM
      Thanks . Our use case was for updates. The vendor existed w/ 1099 Type = NEC and we were NOT passing the 1099 type so it was throwing errors. I was thinking about setting a pre-script to grab the existing 1099 value, having eConnect set it to ‘1’ & then having a post-script set the value back to what it was…
      Thanks . Went ahead and put this in & will report back in the next few days. We have modified post nodes from Binary Stream so tried to piece your code updates into our environment. If it works, I’ll share here as well.??
      Kyle Malone, CPA
    Kyle Malone replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘eConnect & 1099 Nonemployee Compensation (NEC) – Error 3396’ is closed to new replies.
