Deleting old users with TSQL
  • Deleting old users with TSQL
    Posted by Jeff Roe on May 1, 2022 at 1:39 pm
    • Jeff Roe
      May 1, 2022 at 1:39 PM
      I’m in the process of cleaning up old users that either are no longer active or left over from upgrades where user name formats changed. The intent going forward is to keep users in the system after they leave but remove based on record retention policies.
      The current cleanup problem is that I have a hundred plus users that I need to remove.
      While I can use the user admin in GP to delete, that will be time consuming.
      I do know all the tables in the Dynamics DB that reference users.
      Would I be safe to use SQL to remove from those Dynamics DB tables and drop the users from SQL and DB security?
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Jamie Evenson
      May 1, 2022 at 3:06 PM
      Hi Jeff,Ā
      While I usually am happy to support SQL updates, have you thought about using a macro to complete this?Ā  You could record the macro and then build out the code for each user you want to remove. I have used this in the past and it works well.Ā  Let me know if you need more details on this approach.Ā
      Jamie Evenson
      CEO
      Najaxa Software
      Fargo, ND
    • Jeff Roe
      May 1, 2022 at 4:36 PM
      Good idea, I have used macros for other things so i’ll try that
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Jeff Roe
      May 1, 2022 at 5:29 PM
      One problem is that when I delete using GP there is still a trail of the user left related to 3rd party ISV apps like Multi Entity from Binary stream, collector, Extender etc.
      Jeff Roe
      Kele Inc
      Bartlett TN
    Jeff Roe replied 3 years, 10 months ago 1 Member · 0 Replies
The discussion ‘Deleting old users with TSQL’ is closed to new replies.
