Collections Management not attaching invoices to emails
Posted by tdestefano@phigenics.com on August 24, 2018 at 12:55 pm-
Good morning everyone. We are having an issue with Collections Management has stopped attaching invoices to emails we send through it.Ā I’ve checked the settings and all appears correct, but still no attachments.Ā
Has anyone seen this issue in the past or have any suggestions?
Tammy DeStefano
Senior Accountant
Phigenics, LLC——————————
Steve Erbach
MemberAugust 27, 2018 at 10:25 AM
I feel a little foolish making suggestions to someone as experienced as you,
! But the key phrase is, “has stopped”. So the question is, what has changed? Any updates to 3rd-party modules? GP updates? Any email system updates?Regards,
“Sparkly” Steve Erbach – QMS Manager and Business Development Analyst
GLC Minerals, LLC – Green Bay, WI
GP 2016 R2 (16.00.0579) / MR 2012 CU16
Twitter: twitter.com/serbach
Welcome to Dynamics!
You do not have permission.
Call Steve.
(hat tip: Lou Spevack)
?Good Morning Tammy & Steve, Thanks for your input.
Tammy, in regards to this issue, as Steve stated, as anything changed in your process that you believe may/could have caused this?
Any recent upgrades, any recent changes to your invoices reports..?
Please let us know.Ā
Ben Dosso
Professional Advantage
ND
Steve and Ben, Thanks for the follow up!
That’s what is strange, there haven’t been any changes to our system. Further, it seems to be hit or miss. Occasionally (maybe 1 in 10) the invoices attach. I’ve tried recreating when it attaches vs when it doesn’t and can not for the life of me find a pattern.
Everything appears setup correctly as far as I can tell.
The note even refrences that the Invoice was attached,Ā
But, no invoice is attached to the actual email
Any suggestions would be appreciated.
Thank you!——————————
Tamara DeStefano
Phigenics, LLC
?We had the same issue and worked with Professional Advantage to get a work around.Ā We found the inconsistency when using the ’email’ button on the customer account.Ā When you use the ‘contact’ button instead it works.Ā Not an ideal solution, but it couldn’t find another option.Ā We are using Word Templates for our invoices, which may be part of the problem.Ā Since this work around was ok with us, we didn’t go any further.
Amy
Amy Schwent
Vice President, Controller
CCA Global Partners
Earth City MO
?Good Morning Tammy,
Thanks for your update.
A
Can you please provideĀ the Collections About window?Microsoft Dynamics GP > Tools > Setup > Sales > Collections About
B
Also are you currently using the Word Template functionality for your invoices?Ā Ā
Please let me knowThanks
Ben Dosso
ND
Thanks for the suggestion Amy! We will give that a try.
Ben,Ā Ā We are on Version 14.00.0073.000Ā 14.b08Ā and yes we are using word templates for our invoices. Thanks!
Tamara DeStefano
Phigenics, LLC
Good MorningĀ & ,
Thanks for your input/ update.
I just wanted to notify you that in the latest Build of Collections Management, the word template feature has been revived/improved.
I recommend upgrading to this latest Build to take advantage on these improvements.Ā
As of 08/31/2018 please see below the Collections Management latest Build available here.
- GP 2015 CM Version 14 Build 26
- GP 2016 CM Version 16 Build 17
- GP 2018 CM Version 18 Build 8
I also attached for your convenience the release note on GP 2015 associated with Version 14 BuildĀ 26 which goes over these improvements listed under CM-644 and BU-950
Please let me know how it goes after you complete this upgrade to the latest Build.
Ā Ā
Have a good one!
Ben Dosso
ND
tdestefano@phigenics.com replied 8 years, 2 months ago 1 Member · 0 Replies -
The discussion ‘Collections Management not attaching invoices to emails’ is closed to new replies.
