Hi, I’ve got some manufacturing orders that have somehow been closed before their time. I’ve tried to use the edit mo status window, but they are not coming up as able to be changed. Is it possible to re-open a closed mo? #Manufacturing?
—————————— Teresa Waters Controller La Crosse Milling Company Cochrane WI ——————————
Danny Maxwell
September 12, 2019 at 2:15 PM
To theĀ ?best of my knowledge I don’t believe that you can re-open a closed MO, you may have to run an inventory reconciliation on the items that have been affected by the closing process.
—————————— Danny Maxwell Business Analyst AFL Hyperscale Kent Washington —————————— ——————————————-
If the closed MO’s are accurate (for the activity to date), I would not try to reopen them.Ā I would start new MO’s to complete recording the activity remaining.
If the closed MO’s are corrupt (and causing problems) and I cannot do inventory adjustments and/or journal entries to fix it, I would enlist my MS partner to dive into the SQL tables and fix it.
Good luck.
Chris
—————————— Chris Donnelly Sr Mgr of Info Systems and Financial Reporting Healthmark Industries —————————— ——————————————-
Aleiha Hanson
September 16, 2019 at 1:33 PM
I don’t believe you can re-open a closed MO. Like others have said, you can do adjustments and reconciliations to un-do any GL and inventory actions and then create new MOs if needed. Do you still need to report labor and/or inventory against the MO and that’s the reason for re-opening?
—————————— Aleiha Hanson Royal Basket Trucks, Inc – IT Manager GPUG Milwaukee WI Chapter Leader ahanson@royal-basket.com —————————— ——————————————-
