Changes to Batch Control Totals and amounts in GP 18.5
  • Changes to Batch Control Totals and amounts in GP 18.5
    Posted by Howard Blitstein on January 10, 2023 at 1:41 pm
    • Howard Blitstein
      January 10, 2023 at 1:41 PM
      I unfortunately do not get into batch posting but a user is commenting to me that after our upgrade to 18.5 she noticed that the ControlĀ  Total fields have changed a bit.
      When I did in the past I thought you could enter the batch total(dollars) and count(invoices) and then see those numbers reflected after you enter your last invoice. My user is saying it has changed.Ā
      Howard Blitstein
      Najaxa Software
      Sterling Heights
    • Windi Epperson
      January 26, 2023 at 1:24 PM
      Hey
      First check to see if you have a modified version of this window.Ā  You can see that by looking in AdministrationSetupAlternate?/Modified Forms and Reports.Ā
      If you do then you may have to remodify/update the modification of the window for the new version.
      If you don’t have a modified window, then use this chat to ping Terry Heley and see if they are seeing that change in the out of the box code at Microsoft.
      Windi
      Windi Epperson
      Customer Support Manager
      Njevity, Inc
      Norman OK
      720-870-9700 x104
    • Dexterity Developer
      January 30, 2023 at 4:13 AM
      Which Batch window is it?
      dexteritydeveloper
      dexteritydeveloper@gmail.com
      https://keptonworking.blogspot.com/
    Howard Blitstein replied 3 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Changes to Batch Control Totals and amounts in GP 18.5’ is closed to new replies.
