Button Dropdown List in VST
  • Button Dropdown List in VST
    Posted by greg-wahl on April 25, 2018 at 1:46 pm
    • Greg Wahl
      April 25, 2018 at 1:46 PM
      I added a button dropdown list to a window in modifier and I added 3 items to it so when you click on the button, you get 3 choices underneath it.Ā
      Now, in Visual Studio Tools, I can add an eventhandler to the button but I want to add an eventhandler to the 3 individual items under that button so that I can do different things depending upon the selected menu item.Ā  What is the proper VB command to do that?
      The command to add an eventhandler to the actual button is as follows…
      AddHandler EquipmentForm.MaintWindow.LocalBtnImage.EnterAfterOriginal, AddressOf Openbrowser3
      Button List 1
      Greg Wahl
      Senior Database Administrator
      Owensboro Municipal Utilities
      Owensboro KY
    • David Musgrave
      April 26, 2018 at 2:28 AM
      Hi Greg.
      I think that you will need to use pass through sanScript to make this work.
      David
      Managing Director
      Perth, Western Australia
      http://www.winthropdc.com
    • Dan Peltier
      April 26, 2018 at 9:35 AM
      If you’re using Visual Studio, then just type out the object you want the event on, hit period, and scroll through the list of available events. The little lightning bolt means it’s an event. I’m using C#, but it’s close enough to VB to show what to do. The point is, Visual Studio can write the code for you, so long as you know the object.
      Once you have the event, type space += and then you’ll get a popup asking if you want to create the handler.
      Hit tab, and you have a stub handler to put your code.
      If you’re not sure which Event to use, put a MessageBox popup in events until you find the one you want.
      Dan Peltier
      Sr. Support Engineer
      Microsoft
      Fargo ND
    greg-wahl replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Button Dropdown List in VST’ is closed to new replies.
