We had a bank deposit that had a total of $3,439.10 but the deposit amount shows $3,439.11. Not sure how this happened. My issue is that my adjusted book balance for that month is off by .01. It won’t let me do an adjustment for the .01. I am attaching screen shots from the bank recon. The adjusted bank balance is the correct number.
We have seen this, it has to do with the temp files on local client machine. The best fix is to void the deposit and recreate it, it will post with correct totals.
Dynamics GP stores all currency amounts with 5 decimals, both deposited and undeposited receipts are stored in table CM20300. If you look in this table, do you see any of your items with values in more than the first two decimals? I’ve had this happen to me and the culprit was a behind the scenes value in those decimal places. I do not know what caused it, but I simply changed the number at the SQL level and never had another problem. Kind regards, Leslie
—————————— Leslie Vail Accounting Systems Consulting, Inc. Dallas TX —————————— ——————————————-
Arun Vijayakumar
February 6, 2017 at 8:50 PM
Run the following scripts against your company DB and verify if their is any mismatch with the transactions,
Select TRXAMNT,ClrdAmt,ORIGAMT,Checkbook_Amount,* from CM20200 where substring(str(ORIGAMT,10,5), patindex(‘%.%’,str(ORIGAMT,10,5))+3, 1) > 0
In case you modify transaction in above table, you need to change in this table as well
Select CURRBLNC from CM00100 Select DOCAMT from PM30200, Select APFRMAPLYAMT, ActualApplyToAmount, APPLDAMT, ORAPPAMT from PM30300,
—————————— Arun Vijayakumar Omaha NE —————————— ——————————————-
