Bank Rec Enhancement ISV
  • Bank Rec Enhancement ISV
    Posted by Kyle Malone on November 7, 2019 at 4:27 pm
    • Kyle Malone, CPA
      November 7, 2019 at 4:27 PM
      Is anyone using a simple/low-cost solution to provide some enhancements to the existing GP bank rec process?
      Particularly, we’re looking for 2 things.
      – Speed up the time that it takes to open the reconcile bank statement window
      – Ability to search the reconcile bank statement window (let’s say a particular check number) in order to more quickly find transactions & manually reconcile when needed
      Thanks in advance for any recommendations.
      Thank you,
      Kyle
      Kyle Malone, CPA
      Lead Consultant/Blogger – https://alacarteGP.com
      Solugence | Find the software that FITS your business + integrates with GP. Find Software Smarter. https://solugence.com
    • Joseph C. Markovich
      November 8, 2019 at 9:41 AM
      Maybe could create a search screen like he did for PM, RM and SOP?
      Pretty please?
      -Joe
      Joseph C. Markovich
      Okaya Electric America
      Valparaiso IN
    • Steve Endow
      November 8, 2019 at 12:23 PM
      Hi ,
      Thanks for the shout out!Ā
      Unfortunately, I am going to take a guess that reproducing the Select Bank Transactions window would require a fair amount of work, as there is probably a moderate amount of complexity going on behind that window.Ā  (temp tables, status field updates, etc.)
      I suspect that the typical answer would be to use one of the third party GP bank rec modules, but I’m assuming that violates the “low cost” portion (and probably also the “simple” portion) of the OP.
      If there is demand for such a solution, and if there are a few people willing to help out with reverse engineering the window, and if there are a few customers willing to help finance the development (at cost), I’d be open to having my developer work on it.
      Steve
      Steve Endow, Microsoft MVP
      Precipio Services
      Los Angeles, CA
      steveendow (at) gmail (dot) com
    • Kim Peterson
      November 11, 2019 at 9:55 AM
      If you are looking for a way to speed up and improve GP Bank Rec – you need to look at Easy eBank rec.
      GPC Systems, Inc. has a solution called Easy e-Bank Rec – bank reconciliation for Microsoft Dynamics GP.Ā  Eliminate tedious work, save time with automation, have clarity – and make month-end less stressful.
      Adrienne Lilly will be able to answer any questions:
      adrienne@gpcsystems.com
      Kim Peterson
      701-261-7307
      Kim@DynamicsConnections.com
      #KimPetersonGP
    • Kyle Malone, CPA
      November 11, 2019 at 11:17 AM
      Thanks everyone!Ā  We’re going to start with looking @ the off the shelf product(s) & then go from there.Ā  I’ll keep this thread update for future seekers!
      Kyle Malone, CPA
    Kyle Malone replied 6 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Bank Rec Enhancement ISV’ is closed to new replies.
