AP Workflows with Document Attach Issues, Wrong VENDORID and DOCNUMBR
  • AP Workflows with Document Attach Issues, Wrong VENDORID and DOCNUMBR
    Posted by steven.mayhue@stellarmls.com on January 12, 2018 at 3:58 pm
    • Steven Mayhue
      January 12, 2018 at 3:58 PM
      I am on GP2015R2 and have just started using AP workflows.Ā  I am finding that you must attach files from the ribbon to be able to send in emails.Ā  The problem I just encountered was that the DOCNUMBR in the CO00102 table is NOT the DOCNUMBR from the tramsaction, further I am seeing the wrong VENDORID listed in the same table.Ā  Has anyone else seen this behavior?
      I discovered this when my attachment viewer application stopped working for these new attachments which were not attached to Notes. using the query below:
      stringĀ queryĀ =Ā @"SELECTĀ a.VENDORID,
      		Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā CAST(RTRIM(REPLACE(REPLACE(REPLACE(a.DOCNUMBR,'/',''),'.',''),'-',''))Ā asĀ varchar(21))Ā asĀ InvoiceNumber,
      		Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā c.fileName,
      		Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā c.BinaryBlob
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā FROMĀ Ā Ā PM30200Ā a
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā INNERĀ JOINĀ CO00102Ā b
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā ONĀ CONVERT(VARCHAR(MAX),Ā CONVERT(BINARY(4),Ā Cast(a.NOTEINDXĀ ASĀ INTEGER)),Ā 2)Ā =Ā RIGHT(RTRIM(b.BusObjKey),Ā 8)Ā Ā
      		Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā INNERĀ JOINĀ coAttachmentItemsĀ cĀ ONĀ c.Attachment_IDĀ =Ā b.Attachment_ID
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā WHEREĀ a.DOCNUMBRĀ =Ā '{0}'";
      Example data from query now:
      VENDORID DocNUMBR noteindx BusObjKey
      REA03 7539 136817 0PMPayables Transaction History1~00021671
      ROG01 7540 136818 0PMPayables Transaction History1~00021672
      First 2 belong to VENDORID AME01 for Invoice 117129
      second 2 belong to VENDORID TLC01 for Invoice 1074
      Steven Mayhue
      Lead Developer/DBA
      My Florida Regional MLS
      Altamonte Springs FL
    • Mahmood M. AlSaadi
      January 14, 2018 at 5:35 PM
      I have worked with both; workflow and document attachment, but never encountered such a case. May I ask you to use the script on my blog and provide the results back here in the forum ?
      Script >> Attachment Report – All Attachments (Cards and Transactions)
      Your feedback is highly appreciated,
      Mahmood M. AlSaadi – MVP
      Principal Dynamics ERP Consultant
      SIROCo LLC – (844) 708-0008
      McKinney TX
      m.saadi@sirocollc.com
      http://www.sirocotech.com
    • Steven Mayhue
      January 18, 2018 at 3:47 PM
      I found out that the issue is that when using Attachments in Workflows for AP that the BusObjKey in the CO00102 and CO00105 is no longer the hex representation of the NOTEINDX of the PM30200 record.Ā  It is now the VCHRNMBR from the PM30200 record!Ā  In the query below see the change to the ON x=y after the JOIN to CO00102 table.
      Using Notes attachments you get a BusObjKey of the format
      Ā  Ā Ā  0SystemNoteshex representation of the NOTEINDX of the PM30200 record
      Using Attachments from the ribbon you get the formatĀ
      Ā  Ā Ā  0PMPayables Transaction History1~VCHRNMBR from the PM30200 record
      or
      Ā  Ā  Ā 0PMPayables Transaction1~VCHRNMBR from the PM30200 record
      I changed my coded query as shown below:
      BEFORE:
      string query = @”SELECT a.VENDORID,
      CAST(RTRIM(REPLACE(REPLACE(REPLACE(a.DOCNUMBR,’/’,”),’.’,”),’-‘,”)) as varchar(21)) as InvoiceNumber,
      c.fileName,
      c.BinaryBlob
      FROM PM30200 a
      INNER JOIN CO00102 b
      ON CONVERT(VARCHAR(MAX), CONVERT(BINARY(4), Cast(a.NOTEINDX AS INTEGER)), 2) = RIGHT(RTRIM(b.BusObjKey), 8)
      INNER JOIN coAttachmentItems c ON c.Attachment_ID = b.Attachment_ID
      WHERE a.DOCNUMBR = ‘{0}'”;
      AFTER:
      c.fileName,
      c.BinaryBlob
      FROM PM30200 a
      ON a.VCHRNMBR = RIGHT(RTRIM(b.BusObjKey), 8)
      Steven Mayhue
      Lead Developer/DBA
      January 19, 2018 at 12:24 PM
      ?It makes sense, I will test this case in specific and keep you posted in case of any further findings that might be important.
      Best Regards,
      McKinney TX
    • Steven Mayhue
      January 20, 2018 at 9:23 AM
      This was originally from an application I wrote to allowĀ  check signers to pull up the original invoice without needing to log into GP.Ā  The original query I got online and had the match as SUBSTRING(BusObjKey, 16,8) against the hex conversion of the NOTEINDEX.Ā  This works fine for NOTES attachments.Ā  It was only when we began using workflows for AP approvals that we discovered this difference.Ā  You could not use the NOTES attachments in the approval emails, only the ribbon attachments.Ā  In the workflows GP is apparently using the Voucher number directly as a match for the last 8 characters on the BusObjKey.Ā  Why this changed doesn’t make a bit of sense to me?Ā  AT least it gives us something to do with all that spare time we find ourselves with, or not.
      I have seen many of your posts and believe this might be a good one for you to publish to the community regarding attachments and the workflow model within GP since most will find the tried and true query that is not valid in this scenario.
      Steve
      Steven Mayhue
      Lead Developer/DBA
The discussion ‘AP Workflows with Document Attach Issues, Wrong VENDORID and DOCNUMBR’ is closed to new replies.
