adding documents to vendor cards
  • adding documents to vendor cards
    Posted by Ben Micek on February 7, 2017 at 11:25 am
    • Ben Micek
      February 7, 2017 at 11:25 AM
      Is there a way to put in w9’s in the vendor cards? We use GP2015 and I thought this was possible in that version.
      Ben Micek
      Accounts Payable
      Outlook-Nebraska, Inc.
      Omaha NE
    • Shari Bruno
      February 7, 2017 at 12:04 PM
      Hi Ben,
      You will need access to Document Attachment, and then will need to set it up under Administration>Setup>Document Attachment Setup.  Once that’s configured you will be able to attach documents through Vendor Maintenance>Attach, or any of the other modules Cards.  This is also available through Transaction windows but you have to attach the document(s) before posting the transaction.  Once posted you can no longer access the Attach function to add new documents. Through Cards you can continue to attach items as needed.
      Shari Bruno
      Accounts Payable Specialist
      Bible League International
      Crete, IL
    Ben Micek replied 9 years, 9 months ago 1 Member · 0 Replies
The discussion ‘adding documents to vendor cards’ is closed to new replies.
