Adding Budget # Report Manager
  • Adding Budget # Report Manager
    Posted by denise-amundson on February 15, 2021 at 1:19 pm
    • Denise Amundson
      February 15, 2021 at 1:19 PM
      Looking for some assistance.Ā  Currently using GP2018R3 and Management Reporter for FS.
      There were a couple of expense accounts added in October 2020.Ā  Each of these accounts have budget #s or the last e months of 2020.Ā  Those numbers were updated in GP.Ā  However, when printing the FS only one of the accounts shows the budget number.Ā  I deleted, added, run check links and can not get the second account to show the budget numbers.
      Not sure why it worked for one and not the other. Ā
      Any ideas would be greatly appreciated.
      Denise
      Denise Amundson
      Senior Accountant
      Missouri River Energy Services
      Sioux Falls SD
      February 16, 2021 at 7:18 AM
      While I cannot speak directly to what you have going on without screenshots or more detail, I CAN say that there is 1 general rule when it comes to GP and Management Reporter:
      If you see it in GP, but it is not reporting in Management Reporter and you have ensured that the row/column/tree should be allowing the data then the issue is the Data Mart (which is a type of data warehouse used by MR) and it has gotten out-of-sync with GP.Ā  You should rebuild the DataMart.Ā  If you do not know how you’ll need to contact your GP Administrator/IT Department or your partner for assistance.
      If that does not resolve it then you must dive deeper into how the row/column/tree is reporting and make sure that account would show up somewhere.?
      Jo deRuiter
      ?? GPUG AllStar 2019
      ??Granite Award Winner 2018,2019
      Atlanta Chapter Leader
      Credential Council Co-Chair
      Aisling Dynamics Consulting, LLC
      ERP Practice Manager
      9518674366
      Alpharetta, GA
      aislingdynamics.com
    • Derek Krebs
      February 16, 2021 at 11:52 AM
      Few similar and added thoughts to help:
      1. In Management Reporter (MR), go to Tools | Refreshed Cached Financial Data
      2. Restart the Management Reporter Services, go to Tools | Connection where you will see the server where the 2 MR services are located
      3. In MR row, try a wild card range of accounts in row for test to make sure accts are being retrieved, in Column make sure correct budget ID/book code, especially if multiple company that the Budget IDs are the same
      4. All else fails, yes delete the MR data mart: Resetting the Management Reporter data mart | Microsoft Docs
      Derek Krebs
      Sr Consultant, MSX Group
      PROSPERO by MSX Group, http://www.msxgroup.com
      Derek.Krebs@msxgroup.com
    • Denise Amundson
      February 21, 2021 at 3:00 PM
      Hey Derek,
      Thanks for the information.  When doing #2, the following message pops up “the connection can’t be modified while building block are open”.
      Any suggestions, on what that means?
      Sincerely,
      Denise
    • Derek Krebs
      February 21, 2021 at 8:41 PM
      Hi, you cannot have any rows/columns/trees/reports open so go to File | Close all then can to to Tools menu.
      Derek Krebs
    • Denise Amundson
      February 22, 2021 at 12:13 PM
      Thanks again, I’ll give it a try.
      Denise
    denise-amundson replied 5 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Adding Budget # Report Manager’ is closed to new replies.
