Add a caclulated field to a Window
  • Add a caclulated field to a Window
    Posted by MARY MALLAZZO on July 24, 2018 at 1:04 pm
    • Mary Mallazzo
      July 24, 2018 at 1:04 PM
      Hello
      Does anyone know if you can add a calculated field to a window?Ā  I know how to add a field from a table, but not a calculated field. Ā
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Habib Salim
      July 24, 2018 at 1:53 PM
      depending on what that calculation is, you might need to use VBA.
      if it is just a simple calculation – say unit price * quantity type thing you may be able to do taht in the field propertiesĀ
      usuallyĀ  these requests are more complicated…
      Habib Salim
      HSalim & Co. Inc.
      Bronxville NY
      https://pivotviews.com
    • Mary Mallazzo
      July 24, 2018 at 2:36 PM
      it is a simple calculation.Ā  Billed_Amt/ExpectedContract. Ā Ā
      I guess I will take another look at the documentation.Ā  I only remember seeing how to add a field form a table.
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Leslie Vail
      August 25, 2018 at 3:24 AM
      You can certainly enter a custom field, but you will need to do the calculation using VBA. You can also use GP Power Tools from Winthrop DevelopersĀ Winthrop Development Consultants – Products – GP Power Tools
      A lot depends on what you want to do with the calculated balance. If you just want to display on the window rather than actually saving the balance in a table.
      Kind regards,
      Leslie
      Leslie Vail
      DALLAS TX
      leslievail@earthlink.net 972-814-8550
    MARY MALLAZZO replied 8 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Add a caclulated field to a Window’ is closed to new replies.
