4 UP W2 GP 2016
  • 4 UP W2 GP 2016
    Posted by DSC Communities on January 12, 2017 at 11:07 am
    • Michelle Ashby
      January 12, 2017 at 11:07 AM
      We are wanting to use the 4 per one page W-2’s this year.  Has anyone wever used these form with GP and if so how did it work for you and where did you get the corret pre printed forms that worked?
      Thanks in advance!
      Michelle Ashby
      Asst Director of Accounting
      Continental, Inc
      Michelle Ashby
      Continental Design Co., Inc.
      Anderson IN
    • Kelly Whicker
      January 13, 2017 at 8:49 AM
      We use the 4up forms.  They work great.  We purchased ours from Safeguard.  You have to select the form and then you may need to change your printer priorities to legal size paper.  I also have to adjust the vertical and horizontal alignment which is found under the preprinted forms tab on the print screen.  I found I have to set my paper size first and then the alignment and then print.
      Hope this helps!
      Kelly Whicker
      Office Administrator
      CFM MANAGEMENT CO INC
      St Charles MO
    • Elaine German
      January 13, 2017 at 9:01 AM
      Yes, we use these forms every year.  We get them through Greenshades Software, they are not preprinted though, just perforated and then all the info gets printed on the blank forms.
      Elaine German
      Accounting Specialist
      Des Moines Area Regional Transit Authortity
      Des Moines IA
    • Sherlene Sorenson
      January 16, 2017 at 8:52 AM
      Hi Michelle,
      You can get the 4-UP format (also known as 4-Square format) from any supplier that carries them.  I’ve seen a couple version of these.  I have attached an example of the forms that fit the GP report the best
      Sherlene Sorenson
      Sr Implementation Consultant
      InterDyn BMI
      West Fargo ND
    • Michelle Ashby
      January 18, 2017 at 8:21 AM
      Thank you for all of your responses!  I ended up ordering the forms from Deluxe for Microsoft Dynamics.  I got them in yesterday and ran an alignment and they all match up!  YAY!  Thanks again for the responses!
      Michelle Ashby
      Asst Director of Finance
      Anderson IN
    DSC Communities replied 9 years, 10 months ago 1 Member · 0 Replies
The discussion ‘4 UP W2 GP 2016’ is closed to new replies.
