2022 Form 1099-NEC
  • 2022 Form 1099-NEC
    Posted by craig.hoffman@baltimorelabschool.org on December 2, 2022 at 2:24 pm
    • Craig Hoffman
      December 2, 2022 at 2:24 PM
      We just installed the 2022 year-end update (GP 18.3).Ā  While testing the printing of the 2022 Form 1099’s, I noticed that the print alignment is off.Ā  It looks like each Row is one-to-two lines too low on the form.Ā  I was told that there was no fix for this.Ā  Is there?Ā  Also I did not have this problem with the printing of the Form 1096.
      Thank you
      Craig
      Craig Hoffman
      Baltimore Lab School
      Baltimore MD
    • Windi Epperson
      December 2, 2022 at 3:06 PM
      I would first look to see if you have any modified versions of the 1099 forms and if so turn off those version so you can be sure you are using the most recent version of that form as published by Microsoft.Ā  After that, if alignment is still off one of the print dialogue boxes will have options to move the alignment up/down and side-to-side.Ā  Usually a .25 adjustment goes a long way.
      Windi?
      Windi Epperson
      Customer Support Manager
      Njevity, Inc
      Norman OK
      720-870-9700 x104
The discussion ‘2022 Form 1099-NEC’ is closed to new replies.
