2021 Budget
  • 2021 Budget
    Posted by denise-amundson on October 26, 2020 at 8:56 am
    • Denise Amundson
      October 26, 2020 at 8:56 AM
      I am adding budget numbers for the first time.Ā  It appears that the fiscal calendar needs to be set-up for the year 2021.
      Is there anything else that needs to be completed in order to add the budget information?
      The budget information can be added manually or from an Excel import, is that correct?
      Sincerely,
      Denise
      Denise Amundson
      Senior Accountant
      Missouri River Energy Services
      Sioux Falls SD
      October 26, 2020 at 9:04 AM
      You are right on all counts and you should have nothing else to do.
      I would suggest that if you are going to use the Excel import you use the wizard to ‘create’ a budget, then download it so that you have the correct format.Ā
      Be advised that it will NOT allow you to import the budget back if any of the columns are changed, so you can’t add any columns nor remove any columns and the column headers have to be identical to the downloaded version.Ā  The total column and row also has to exist.Ā  This is really the only ‘picky’ thing about it.?
      Jo deRuiter
      ?? GPUG AllStar 2019
      ??Granite Award Winner 2018,2019
      Atlanta Chapter Leader
      Credential Council Co-Chair
      Aisling Dynamics Consulting, LLC
      ERP Practice Manager
      9518674366
      Alpharetta, GA
      aislingdynamics.com
    • Denise Amundson
      October 26, 2020 at 9:09 AM
      Jo,
      Thanks for the speedy response.
      Denise
      Denise Amundson
      Senior Accountant
      Sioux Falls SD
    • Lisa Levendusky
      October 27, 2020 at 9:20 AM
      I’ve imported them using an Excel template, but I just recently added our FY21 budgets using a Dynamics macro and Replicator from @John Arnold. Ā ?http://rnoldz.com/replicator/Ā  It was a lot less prep work, and not as touchy as the excel import method.Ā  Let me know if you’re interested in hearing more.
      Lisa Levendusky
      Exceptional Persons, Inc.
      Waterloo IA
    denise-amundson replied 6 years ago 1 Member · 0 Replies
The discussion ‘2021 Budget’ is closed to new replies.
