The code is trying to connect directly to SQL rather than access a table so that does not identify the product.
The ability to set the SQLLastUser to nothing is in the Dex.ini Configuration window, not the Dex.ini Settings window. It is a different window under the Setup menu.
However, the only way to identify the product causing the issue now would be to temporarily remove products from the launch file.
Once the extra login issue is fixed, you probably will not need to clear SQLLastUser.
Please update GP Power Tools to build 31.3 as there are a few issues fixed.
