First off, what version of GP are you on? Starting with 2018GP it should pull the name on the check inside PM30200 (VNDCHKNM), not the Vendor Name.
There was a bug in 18.3 that also created this, but fixed in newer releases.
It has nothing to do with address codes…
(I am assuming you are NOT using Mekorma)
If you can provide a pic of the Vendor Card…
Login
Block Member?
See blocked member's posts
Mention this member in posts
Invite this member to groups
Message this member
