In Purchasing the Document Number is the Vendor’s Invoice Number and the Voucher Number is YOUR key field for that purchasing document – you should rarely be changing the Voucher Number unless you were specifically asked to.
In Sales, the Invoice Number is YOUR invoice number to the customer and is 100% unique. The PO Number field in Sales (whether Receivables or Sales) is good for Customers PO Number, which is generally what you are getting from a Customer)
If you are trying to use a separate source-systems invoice information, if it is done right, you can use those source-system numbers as your sales-invoice numbers already – you can use it in the integration to replace the default invoice numbers in GP.
Otherwise, let me advise against a developer just for User Defined (UDF) Fields in GP – the best product there is for this is eOne’s Extender and you can create tons of custom fields and report on those as well.
