Have you looked at the Mekorma Checkbook Setup Window?
From the Mekorma Area Page – select Setup | Purchasing | Checkbook Setup
Under the EFT Remittance Options, verify it is NOT set to Dynamics GP Report Writer. Select EFT Remittance Format, and then use the lookup to select the desired format from Mekormaās full library of PDF formats.
