What you experienced is not common. But, it does happen every now and then. I bet it was caused by a network or server hiccup. It sounds like you’ve taken the adequate/typical measures to ensure the integrity of your data and system.
You may also want to do these to sleep better at night…
– Ensure everything posted to GL ok.
– Run reconcile and checklinks. If these are new to you, do some research. There are some safety measures you should take (i.e. take an outage and run full SQL backups).
