view not visible in ax aot
  • view not visible in ax aot
    Posted by DSC Communities on January 6, 2017 at 2:57 am
    • wattana thasriphet
      January 6, 2017 at 2:57 AM
      I create sql view on SQL Server(ax database) but view not show in ax aot (data dictionary –> view).
      wattana thasriphet
      TBSP,Thailand
    • Tony Zeigler
      January 9, 2017 at 10:05 AM
      The correct process is to create the view in AX’s AOT structure, then synchronize the database.
      Tony Zeigler
      Strategic Solutions NW, LLC
      Beaverton OR
    • Jackie Olson
      January 9, 2017 at 11:41 AM
      If you do not create it in the AOT, the next time you run an AOT synch, it will delete the object from SQL.
      Jackie Olson
      Stoneridge Software Inc.
      Barnesville MN
    • Scott Morley
      January 6, 2017 at 12:28 PM
      Wattana,
      For items to appear in the AOT you have to create them from the AOT. The view you created in SQL cannot be made visible in the AOT, you need to create a view in the AOT and it will push it to SQL. If you don’t want to do that, you can access the view from AX through an ODBC call in a class. It wont add it to the AOT but you will be able to use it. The ODBC call is supported but not best practice.
      If you are new to views in AX you can find information about them and how to create them at View Basics [AX 2012]
      Microsoft remove preview
      In Microsoft Dynamics AX, you can use views where you use tables. For example, you can use a view in a form, a report, and in X++ code. The following table shows the benefits of using a view instead of a table.
      View this on Microsoft >
      Scott Morley
      OneNeck IT Solutions
      Bend OR
    DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies
The discussion ‘view not visible in ax aot’ is closed to new replies.
