User AX System Freeze
  • User AX System Freeze
    Posted by DSC Communities on January 13, 2017 at 2:25 pm
    • Faygen Grant
      January 13, 2017 at 2:25 PM
      Good day,
      I have an end user whose AX system has frozen and is unable to do any transactions. While attempting to edit a PO, she would have received the error message “Changes to the document are only allowed in state draft, because change management is activated.” After this she could not select anywhere in the Procurement and Sourcing module without receiving the same error.
      Any ideas as to what can be done to “reactivate” her user?
      Regards
      Faygen Grant
      Bermudez Group Limited
      Mt. Lambert
    • Beth Brooks
      January 16, 2017 at 7:56 AM
      Have you tried deleting the AUC file?   Not sure what version of AX you are using. We use AX2009 and deleting AUC files seems to help for odd situations like the one you are describing.
      Beth Brooks
      IS Manager
      Camco Manufacturing, Inc
      Greensboro NC
    • Joe Wiley
      January 16, 2017 at 10:27 AM
      You may find it helpful to delete Usage Data for that user (or have them do so).  You needn’t delete it all if the user has many form customizations, but instead can delete certain usage data lines.  For the issue you experience, I suggest deleting Class usage data as a first step.
      Joe Wiley
      Masonite
      Tampa FL
    • John Adler
      January 16, 2017 at 1:10 PM
      Hi. Have you also tried user usage data. If it is defined to a user it could be this.
      Cheers
      John Adler
      Systems Analyst
      Dairy Goat Co-operative (NZ) Ltd
      Hamilton
    • Doug Hoffman
      January 16, 2017 at 2:58 PM
      We get this error quite a bit, related to workflow status. Was this PO already submitted to a workflow approval queue?
      Doug Hoffman
      Applications Analyst
      Depomed, Inc.
      Newark CA
    • Lloyd Dehn
      January 17, 2017 at 8:10 AM
      If you are using workflow you have the option to recall the workflow which brings it back to a status of draft.
      Lloyd Dehn
      Dynamics AX Lead Developer
      Braun Intertec
      Bloomington MN
The discussion ‘User AX System Freeze’ is closed to new replies.
