unable to acquire Fixed asset
  • unable to acquire Fixed asset
    Posted by nazimlalji@hotmail.com on April 3, 2020 at 10:55 pm
    • Najeem JanatAli
      April 3, 2020 at 10:55 PM
      Hi All
      While running FA acquisition, keep getting below error message for only fixed asset, However for other asset able to acquire
      Microsoft.Dynamics.Ax.Xpp.InfoException: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.InfoException’ was thrown.
      at Microsoft.Dynamics.Ax.MSIL.Interop.throwException(Int32 ExceptionValue)
      at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.callReturn(Int32 rc, interpret* ip)
      at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.CallStatic(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs, Type[] varargsTypes)
      at Microsoft.Dynamics.Ax.Xpp.XppObjectBase.StaticCall(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs)
      at Dynamics.Ax.Application.Debug.assert(Boolean expression)
      at Dynamics.Ax.Application.AssetProposalAcquisition.Run() in AssetProposalAcquisition.run.xpp:line 215
      at Dynamics.Ax.Application.AssetProposal.runIL(Object[] _parameters) in AssetProposal.runIL.xpp:line 31
      at AssetProposal::runIL(Object[] )
      at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
      at Dynamics.Ax.Application.SysDictClass.invokeStaticMethod(Object[] _params) in SysDictClass.invokeStaticMethod.xpp:line 26
      at SysDictClass::invokeStaticMethod(Object[] )
      at Microsoft.Dynamics.Ax.Xpp.PredefinedFunctions.runAsInvoke(String className, String staticMethodName, Object[] parms, Object[]& exportInfolog)
      Please advise
      Thanks and knd regards
    • Nandita Nityanandam
      April 10, 2020 at 3:20 AM
      Hi Najeem,
      It seems that system is trying to find the invoice lines related to the transaction and is not able to. It will be required to debug the code and find whether there is an issue with generating invoice. The system is showing trace log, but the actual error is not visible.
      Can you please provide the Dynamics AX version detail? This will help with finding the actual error. There was a known bug in AX 2012 related to it and a hotfix is also available to resolve the issue.
      This answer is provided by Krupa Shar, Sr. Software Engineer, Dynamics 365FO, Synoptek.
      Nandita Nityanandam
      Marketing Head
      Synoptek
      Oakbrook Terrace IL
    • Rahul Mohta
      April 10, 2020 at 7:45 AM
      you should also check on FA books
      and inĀ Fixed assets parameters checkĀ Allow asset acquisition from Purchasing is allowed
      if still having issue could share the setup books and error screen
      Regards
      Rahul Mohta
      Advisor – D365FO
      Real Dynamics
    nazimlalji@hotmail.com replied 6 years ago 1 Member · 0 Replies
The discussion ‘unable to acquire Fixed asset’ is closed to new replies.
