The 1099 federal or state amount cannot exceed the Total amount
  • The 1099 federal or state amount cannot exceed the Total amount
    Posted by DSC Communities on January 31, 2017 at 11:34 am
    • Jim Czerniak
      January 31, 2017 at 11:34 AM
      We are getting the error message “The 1099 federal or state amount cannot exceed the Total amount”  when attempting to confirm a purchase order for certain vendors.  This just started happening so I am not sure what has changed in the system that is causing this.  Has anyone had any experience with this before?
      Jim Czerniak
      Applications Developer
      CMC Group
      Bowling Green OH
    • Rowshon Papri
      February 1, 2017 at 1:40 PM
      Please check on the 1099 fields for the PO lines. It is under the “Setup” tab from the “Line details” fast tab of a PO line. It sounds like 1099 amount on the PO line is greater than the PO line amount. You should be able to manually adjust the amount on the 1099 amount field.
      Rowshon Papri
      AX Implementation Specialist
    • Jim Czerniak
      February 1, 2017 at 3:00 PM
      Thanks for the reply.  I understand what you are saying, but do you know where it pulls in the value from intially?  How would it get greater than the line amount?
      Jim
      Jim Czerniak
      CMC Group
      Bowling Green OH
    • Rowshon Papri
      February 2, 2017 at 2:51 PM
      Please see the attachment. AX is designed to setup tax 1099 amount from PO line amount. When a qty is updated on the grid, AX triggers modified method in order to populate tax 1099 amount on the PO line. You need to involve a developer for this task. You can place a break point on this method to investigate your issue in detail. I wasn’t able to replicate it on my end. Good luck.
      Rowshon Papri
The discussion ‘The 1099 federal or state amount cannot exceed the Total amount’ is closed to new replies.
