Sql Query to Summarize Security Role Duties
  • Sql Query to Summarize Security Role Duties
    Posted by DSC Communities on January 26, 2017 at 2:37 pm
    • Mark Schurmann
      January 26, 2017 at 2:37 PM
      We are implementing D365 for Operations.
      I’m trying to write a query to give me an overview of the security role duties we have setup for our users.  I’m having trouble figuring out how to join the SecurityRole to the SecurityDuty.  Here is what I have so far.  I would expect a table like SecurityRoleSecurityDuty but nothing is jumping out at me.
      select sr.name as SecurityRole,ssr2.name as SecuritySubRole, ssr2.[Description],sd.Name, sd.[Description]
      from SecurityRole sr
      join SecuritySubRole ssr on ssr.SecurityRole = sr.RecID
      join SecurityRole ssr2 on ssr.SecuritySubRole = ssr2.RecID
      join ??? srsd on srsd.SecurityRole = ssr2.RecID
      join SecurityDuty sd on sd.RecID = srsd.SecurityDuty
      where sr.name like ‘APCO%’
      Order by sr.Name, ssr2.name
      Can anyone fill in the ???
      I think this would be a handy report for auditors
      Thanks.
      Mark Schurmann
      Automobile Protection Corp
      Norcross GA
    • Scott Morley
      January 26, 2017 at 3:41 PM
      Mark,
      Taking out the sub roles (there aren’t very many in my system), I got this to work:
      select sr.name as SecurityRole,sd.Name, sd.[Description]
      join SECURITYROLEDUTYEXPLODEDGRAPH srsd on srsd.SecurityRole = sr.RecID
      where sr.name like ‘Aud%’
      Order by sd.Name
      Hope that helps!
      Scott Morley
      OneNeck IT Solutions
      Bend OR
    • Chris Vaughn
      January 27, 2017 at 10:16 AM
      Mark – Here is a script I used to get all roles and their associated duties. Be aware this is for ALL security roles whether they’re assigned or unassigned.
      /****** Roles with Associated Duties ******/
      SELECT
         SECURITYROLEDUTYEXPLODEDGRAPH.SECURITYROLE
         ,SECURITYROLE.NAME AS ‘ROLE’
         ,SECURITYROLEDUTYEXPLODEDGRAPH.SECURITYDUTY
         ,SECURITYDUTY.NAME AS ‘DUTY’
         ,SECURITYDUTY.DESCRIPTION AS ‘DESCRIPTION’
      FROM [DBO].[SECURITYROLEDUTYEXPLODEDGRAPH]
         JOIN DBO.SECURITYROLE ON (SECURITYROLE.RECID = SECURITYROLEDUTYEXPLODEDGRAPH.SECURITYROLE)
         JOIN DBO.SECURITYDUTY ON (SECURITYDUTY.RECID = SECURITYROLEDUTYEXPLODEDGRAPH.SECURITYDUTY)
      — WHERE SECURITYROLE = ‘242’
       ORDER BY ROLE, DUTY
      Chris Vaughn
      Business Analyst – Contura Energy
      Bristol TN
    • Mark Schurmann
      January 31, 2017 at 9:43 AM
      Thanks for the help. My Model table is currently empty.  Not sure if this is because of a change in D365.
      The magic I was looking for was the SECURITYROLEDUTYEXPLODEDGRAPH table.  Here are the queries I came up with to solve my problem.
      –Duties assigned to roles
      select sr.name as SecurityRole,ssr2.name as SecuritySubRole, ssr2.[Description] as SecurityRoleDescription,sd.Name DutyName, sd.[Description] as DutyDescription
      left outer join SecuritySubRole ssr on ssr.SecurityRole = sr.RecID
      join SECURITYROLEDUTYEXPLODEDGRAPH srsd on ssr2.RecID = srsd.SecurityRole
      Order by SecurityRole, SecuritySubRole,DutyName, DutyDescription
      — Users assigned to Roles
      select sr.Name as SecurityRole, u.Name as UserName
      join SecurityUserRole sur on sr.RecID = sur.SecurityRole
      join userinfo u on u.ID = sur.USER_
      Order by sr.Name, u.Name
      Mark Schurmann
      Norcross GA
    • Sherry Moran
      January 27, 2017 at 11:42 AM
      We’re on AX2012 R2 and I created the following view, I found that I had to join data from model to get everything I needed.
      CREATE VIEW [dbo].[KEY_VIEW_UserSecurityRoles]
      AS
      SELECT SUR.USER_, U.NAME as UserName, MSR.NAME AS RoleName, CASE WHEN msr.LABEL LIKE ‘@%’ THEN msr.NAME ELSE msr.label END AS KeyName,
      CASE WHEN SUR.ASSIGNMENTSTATUS = 1 THEN ‘GRANTED’ WHEN SUR.ASSIGNMENTSTATUS = 2 THEN ‘DENIED’
      ELSE CAST(SUR.ASSIGNMENTSTATUS AS varchar) END AS ASSIGNMENTSTATUS,
      CASE WHEN SUR.ASSIGNMENTMODE = 1 THEN ‘MANUAL’ ELSE ‘AUTOMATIC’ END AS ASSIGNMENTMODE,
      U.ID, U.RECID, CASE WHEN U.ENABLE = 0 then ‘DISABLED’ ELSE ‘ENABLED’ END AS STATUS
      FROM dbo.SECURITYUSERROLE AS SUR LEFT OUTER JOIN
      AX2012_LIVE_model.dbo.ModelSecurityRole AS MSR ON SUR.SECURITYROLE = MSR.ROLEHANDLE LEFT OUTER JOIN
      dbo.USERINFO AS U ON SUR.USER_ = U.ID
      Sherry Moran
      SR Business Systems Analyst
      Key Technology, Inc
      Walla Walla WA
    • Lloyd Dehn
      January 30, 2017 at 9:18 AM
      Updated the SQL to use the label text for the security role name when a label is used.
      SELECT sur.USER_ AS UserId,
      u.NAME AS UserName,
      msr.NAME AS RoleName,
      CASE
      WHEN msr.LABEL LIKE ‘@%’ THEN mel.Text
      ELSE msr.LABEL
      END AS RoleLabel,
      CASE
      WHEN sur.ASSIGNMENTSTATUS = 1 THEN ‘GRANTED’
      WHEN sur.ASSIGNMENTSTATUS = 2 THEN ‘DENIED’
      ELSE CAST(sur.ASSIGNMENTSTATUS AS varchar)
      END AS AssignmentStatus,
      CASE
      WHEN sur.ASSIGNMENTMODE = 1 THEN ‘MANUAL’
      ELSE ‘AUTOMATIC’
      END AS AssignmentMode,
      u.ID,
      u.RECID,
      CASE
      WHEN u.ENABLE = 0 THEN ‘DISABLED’
      ELSE ‘ENABLED’
      END AS STATUS
      FROM dbo.SECURITYUSERROLE AS sur
      LEFT OUTER JOIN AX2012Prod_model.dbo.ModelSecurityRole AS msr ON sur.SECURITYROLE = msr.ROLEHANDLE
      LEFT OUTER JOIN AX2012Prod_model.dbo.ModelElementLabel AS mel on mel.Module = msr.LABELMODULE and mel.LabelId = msr.LABELID and mel.Language = ‘en_us’
      LEFT OUTER JOIN dbo.USERINFO AS u ON sur.USER_ = u.ID
      Lloyd Dehn
      Dynamics AX Lead Developer
      Braun Intertec
      Bloomington MN
The discussion ‘Sql Query to Summarize Security Role Duties’ is closed to new replies.
