Setting up Account Structure in AX 2012 R3
Posted by nazimlalji@hotmail.com on December 16, 2018 at 7:47 pm-
HI All
I have following requirement for Account structure and dont want to set up account structure for each series separatly
1.Business unit : default (BS) or the value from drop down but now blank allowed
2.Cost centers N/A for Balance sheet but mandatory for P&L
3,Location N/A for some accounts in operating expensesAlso what does this “” implyĀ
Did any one have any documentation to share regarding various choices to set up Account structure
Thanks and kind regards
Nazim Lalji
Dynamics AX Analyst——————————
The straight forward way to do that (and best practice, IMO) is to have 3 structures:
1. for B/S accounts: business unit
2. for most P&L accounts: business unit and cost centre
3. rest of expense accounts: business unit, cost centre, and location.Alternatively, instead of (3) you can create advanced account structures to add location to just some fields (there are all kind of considerations whether to go in that direction, such as if you use budgeting – advanced structures not compatible with budgets).
What is the reason you do not want more than one account structure?
Zvika Rimalt
Functional Consultant
Vancouver BC
Thanks Zvika
Here is the issue
Current asset : Project (default -000 and drop down)
Fixed assets: Dept, project, site (site 000 and drop down
Liabilities : projects,
Deferrend liabiliies : product line, dep, projectits pretty complicated with account ranges like :0000-1999, 2000-3999, 4000,5999
Also what does that meansĀ in dimensionĀ dept “”
Nazim Lalji
Dynamics AX Analyst
Nazim Lalji
Los Angeles CA
Stacy Black
MemberDecember 17, 2018 at 10:21 AM
Hello Nazim,With the information you provided you would have to setup Advanced rules for the structures to use only one.Ā I would recommend that you use two at least, one for Balance Sheet and the second for the P&L accounts.
To answer your questions about the “”, this states you are allowing blanks and should be a green check mark on the structure segment).
Stacy Black
Senior Application Consultant
MCA Connect
Denver CO
Thanks Stacy
But dont have expertise or material on net regarding set up of Advanced structures
just want to avoid that many lines likeAttachment is attached
Nazim Lalji
Dynamics AX Analyst
Nazim Lalji
Los Angeles CA
Ludwig Reinhard
MemberDecember 17, 2018 at 11:47 PM
Hi Nazim,
You can find some information on advanced rule structures here
https://docs.microsoft.com/en-us/dynamicsax-2012/appuser-itpro/create-advanced-account-structures-and-rules-for-a-chart-of-accounts
There are a lot of additional videos and blog posts available. Just Google for advanced rules and you will find them.
Best regards
Ludwig——————————
Ludwig Reinhard
Sycor
Goettingen
Brian Kalfus
MemberDecember 18, 2018 at 7:58 AM
My organization had some detailed requirements for its gross margin accounts/cost centers, so we set up advanced rules, which served our purposes for journal entries.Ā When you enter one, the system applies the logic of the advanced rules and when you click the drop down arrows, it will let you select the dimension according to the account you entered and any previous dimension(s).Ā This is a neat feature.Ā What is not so neat is that when it came time to enter our budget, the dimensions set up in the advanced rules did not appear in the Dimensions for Budgeting box.Ā In other words, you can’t budget down to the detail of all your dimensions.Ā (Zvika mentioned this in his reply.)Ā You will need to remember this if you intend to use the budget module with AX 2012 R3.Ā Our implementation partner gave us a workaround to get our budget loaded, which was a lot of extra work for me.Ā So keep this in mind.Ā I am told that this problem will not happen in Dynamics 365 for Operations.Ā Can anyone confirm this?——————————
Brian Kalfus
Unigroup
FENTON MO
nazimlalji@hotmail.com replied 7 years, 10 months ago 1 Member · 0 Replies -
The discussion ‘Setting up Account Structure in AX 2012 R3’ is closed to new replies.
