Security Error – Price Agreement journal – edit in excel
  • Security Error – Price Agreement journal – edit in excel
    Posted by dan-cantley-1 on May 4, 2017 at 3:39 pm
    • Dan Cantley
      May 4, 2017 at 3:39 PM
      I have a user that gets into the sales & marketing > journals > Price/Discount Agreement journal.
      opens the lines, marks the lines they want to change and then uses [Edit in Excel]
      They then makes the price changes – but when they try to publish them back into AX gets the following error:
      “User ‘Joe.smith’ is not authorized to select a record in table ‘RetailCatalogPriceGroup’. Request denied.Cannot select a record in Catalog price groups (RetailCatalogPriceGroup).”
      What would be causing this error and how would I fix it (other than making them SysAdmins)
      Not sure why it would be throwing that error since they are only changing a couple prices, not creating a new PriceGroup.
      As SysAdmin, I have no problem making changes – and I see it is using PriceDiscAdmTransService when I do publish. Ā Do I only need to add a Privilege to access that service? Ā I thought when a user doesn’t have security for a service it says they don’t have security for accessing a class, not a table.
      If someone could point me in the direction I need to go – it would be appreciated. Ā Thanks!
      Dan Cantley
      Systems Analyst
      Bedrock Manufacturing Co, LLC
      Detroit MI
    • AndrĆ© Arnaud de Calavon
      May 5, 2017 at 3:21 AM
      Hi Dan,
      Indeed ensure the user has access to the service with a correct privilege/duty. The service operations do have a permissions node with table permissions. You can also do some table access overrides on the security role level.
      kind regards,
      AndrƩ Arnaud de Calavon
      Kaya Consulting
      The Netherlands
    • Dan Cantley
      May 5, 2017 at 6:58 AM
      Thanks. Ā Will set that up and test.
      Dan Cantley
      Systems Analyst
      Detroit, MI
    dan-cantley-1 replied 9 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Security Error – Price Agreement journal – edit in excel’ is closed to new replies.
