I have seen many posts as to how to create a Derived Financial Hierarchies, I have yet to come across one as to how to report using these.
Can anyone point me to how I can report on these?
—————————— Jonathan Struble Campus Management Bel Air MD ——————————
Chad Carnes
August 29, 2019 at 2:26 AM
Jonathan,
I am not sure what you are looking for report wise.Ā
You can see these in the Trial Balance, Voucher transactions or the dimension statement report.
The derived dimensions just default on objects (default dimensions) on things like Item, Project, Vendor, Customer or Fixed Asset. This is so you could enter in BU and then everything just populates.
Additionally, the other big reason I set this up is for AP invoice processors. if they have 3 dimensions to populate and it is turned on then they could populate the BU and all the rest might populate. This is where the defaults and updates happen on “Ledger Dimension” in the journal itself.
There is no specific report for that all these dimensions just pass through to the Ledger Transactions and you can see them there.
Hope this helps???
Chad
—————————— Chad Carnes Director of Consulting and Solutions EmpowerAX McKinney TX —————————— ——————————————-
Jonathan Struble
August 29, 2019 at 12:02 PM
Thanks Chad,
I guess what I am not understanding is how they appear in the Trial balance for example.Ā Can you supply a screen shot or description as to how/where I would see reporting by these?
Thanks again !
—————————— Jonathan Struble Supervisor RSM Bel Air MD —————————— ——————————————-
