Purchase Order transfer between interCo
  • Purchase Order transfer between interCo
    Posted by nazimlalji@hotmail.com on April 15, 2019 at 7:58 pm
    • Najeem JanatAli
      April 15, 2019 at 7:58 PM
      Hi All
      Recently I came up with this requirement from our client, to transfer PO from one Company to another. As per my understanding since PO is the contractual document from a company to vendor so in AX there is no any option to move from PO from one company to another.
      Anyone want to give a feed back or please advise is it possible
      Thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    • David Scattergood
      April 16, 2019 at 3:41 AM
      Hi Nazim
      I’m not sure I fully understand the requirement or the scenario behind the requirement, please can you elaborate as I might be able to provide a better response. If this is simply to correct something raised in error surely they should be so few and far between that recapturing is not a major heartache, if this is happening more frequently then maybe it would be better to do something that reduces the possibility?
      Out of the box, the ability to transfer a PO is not available and you can’t even create a new PO in the other entity and then copy the lines from the PO in the original entity.Ā
      Regards
      Dave
      David Scattergood
      P2 Dynamics Solutions Ltd
      Corby
    • Najeem JanatAli
      April 17, 2019 at 4:20 PM
      HI David
      Its kind of once in while, however when users know its fixable it will happen more šŸ™‚Ā
      PR for Company A however later realize its expense for Co B, and shouldnt be through CO A. To transfer PO from CO A to CO B, so expense and vendor can be booked in CO B and vendor can be paid by CO B
      Purchase orders are in both stages: Approved and confirmed.Ā
      There is a workflow at PRĀ  level, after all the approval workflow completed and it create PO
      Thats the scenario what you suggest
      Nazim Lalji
      Dynamics AX Analyst
    • Ted Jillett
      April 22, 2019 at 7:12 AM
      Nazim;
      Ā  Ā Can you please state what version of AX you are using?
      This should be noted in all discussions.Ā
      Once a requisition has been submitted, fully approved, and converted to purchase order the entity (company) that was selected during the create state is locked.Ā
      We’re currently on 2012 R3 and the ability to change this would have to be done prior to submitting for approval.
      #UnifiedOperations
      #AX2012
      #Functional???
      Ted Jillett
      Business Systems Analyst, Manufacturing AX
      Insulet Corporation
      Acton MA
    nazimlalji@hotmail.com replied 7 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Purchase Order transfer between interCo’ is closed to new replies.
