Project export (Dev) and Import (PROD) in AOT
  • Project export (Dev) and Import (PROD) in AOT
    Posted by nazimlalji@hotmail.com on April 11, 2019 at 3:13 pm
    • Najeem JanatAli
      April 11, 2019 at 3:13 PM
      Please can any one advise steps and check marks to export and import project (code or script) from Test environment to Prod environment
      Any check mark required
      EXPORT
      Import
      what are the next steps like:
      -Generate full CIL or
      -Increemental CIL
      -Does Sync required
      Please advice
      Thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    • Cruz Margaix
      April 12, 2019 at 4:02 AM
      Hi Nazim
      First of all, please take into account that importing code from a project in Production is not recommended. A best practice is to deploy the updated models.
      Having said that, if you’re exporting/importing projects, the recommendations with regards to checkboxes would be:
      EXPORT:
      – Application Object Layer = Yes
      Ā Select the layer from where you want to export your modifications. If you’re a customer, this would typically be CUS or USR.
      – Export Labels : Select only when you’ve created new labels as part of your development. Please be aware that importing/exporting labels is a bit tricky and not always works nicely.
      Again, ideally labels files should be deployed to prod instead of labels being installed via projects.
      IMPORT:
      – Delete sub-elements = NO
      – If you’ve exported with labels –> Select “Application objects and labels”, otherwise “Only application objects”.
      – Show details will show you which objects are going to be imported, but it won’t have any effect on the import process itself.
      With regards to the next steps:
      – Full compile
      – DB sync if your project includes data model elements
      – It should be enough with incremental CIL compile, although I would recommend full CIL.
      – If you’re transferring labels, a label cache clean may be needed (or alternatively a restart of AOSs)
      Hope this helps.
      Cruz
      Cruz Margaix
      Senior Architect
      SAGlobal
      Valencia (Spain)
    • Najeem JanatAli
      April 15, 2019 at 5:01 PM
      Thanks Cruz for you help
      Successfully exported projectĀ
      Nazim Lalji
      Dynamics AX Analyst
    nazimlalji@hotmail.com replied 7 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Project export (Dev) and Import (PROD) in AOT’ is closed to new replies.
