Periodic Journal error on Retrieval
  • Periodic Journal error on Retrieval
    Posted by Arush Kuthiala on April 26, 2020 at 11:10 am
    • Arush Kuthiala
      April 26, 2020 at 11:10 AM
      Has anyone received the error message before when they are retrieving a journal saying “Journal XXXX is not available for use. Please select another journal”? As far as I can tell the periodic journal is exactly like all of our other ones, the line exists and there is a date in it.Ā
      Arush Kuthiala
      Western Computer
      Toronto ON
    • Juan Sebastian Grijalba
      April 27, 2020 at 11:27 AM
      Yes this is a known issue, please seeĀ KB 4556580 on LCS for a workaround. “If the user trying to retrieve the periodic journal isn’t assigned to a User group, this error will be thrown. The bug is that user are not required to be part of a user group, so this will be fixed and will not be required any more.
      Until the bug fix is available, an organization can work around the issue by creating a ‘dummy’ user group and assign all users to the user group. Any users that are part of a valid user group would not need to be added to this dummy user group. After the fix is available, the dummy user group can be removed. “
      Berkowitz Pollack Brant
      Miami
    • Arush Kuthiala
      April 27, 2020 at 11:56 AM
      Wow would never have thought of that solution but it worked, thank you!
      Arush Kuthiala
      Western Computer
      Toronto ON
    • Amy Akley
      April 27, 2020 at 11:58 AM
      Arush,
      Assuming you are using D365. We experienced this as well. We thought it was a security issue but it turns out it is a validation issue. Our D365 IT person figured out that D365 has added some new validation around periodic journals. D365 is making sure the user requesting the periodic journal is also a member within the usergrouplist table. Once we added the individual who was receiving the error, she was able to use the periodic journal in question.
      Hope this helps!
      Amy Akley
      Sr. Financial System Analyst
      XTRA Lease
      Saint Louis MO
    • Arush Kuthiala
      April 27, 2020 at 2:51 PM
      Thank Amy! This resolved our issue.
      Arush Kuthiala
      Western Computer
      Toronto ON
    Arush Kuthiala replied 6 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Periodic Journal error on Retrieval’ is closed to new replies.
