Migrating Company setups across environments
  • Migrating Company setups across environments
    Posted by Dustin Sanders on January 11, 2018 at 11:02 am
    • Dustin Sanders
      January 11, 2018 at 11:02 AM
      ?Hi All,
      Does anyone know if there is a supported mechanism from Microsoft to migrate company setups over to different environments?Ā  We have around 12 companies we will be creating for our next implementation, and there is a desire from the project team to do the 12 company setups once and migrate those setups across to otherĀ testingĀ environments andĀ eventually productionĀ so that they do not have toĀ complete the setupsĀ manually for several times.Ā
      So far I have not been able to find any officially supported way to do this, and our implementation partner mentioned the same.Ā  Hoping someone how has been working in multi-company environments may have some ideas on this.
      Dustin
      Dustin Sanders
      Allegion
      Carmel IN
    • Kaare Boraas
      January 12, 2018 at 9:38 AM
      Use the data management workspace to export your configuration from your source instance and import it into your destination instance.Ā  That approach is dependent on data entities and you knowing your data.
      Kaare Boraas
      Solution Delivery Manager
      PCL Constructors Inc.
      Edmonton AB
    • Zvika Rimalt
      January 12, 2018 at 5:22 PM
      Kaare, are you referring to the Export/Import options or to the “Copy into Legal Entity” options on the workspace?
      Zvika Rimalt
      Functional Consultant
      Vancouver BC Canada
    Dustin Sanders replied 8 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Migrating Company setups across environments’ is closed to new replies.
